decorators3 Posted April 22, 2022 Share Posted April 22, 2022 for some reason any objects .. cabinets etc. have an artwork finish that I used on a specific picture .. How do I get back to things back to normal Thanks Levina Link to comment Share on other sites More sharing options...
robdyck Posted April 22, 2022 Share Posted April 22, 2022 There could be several reasons, but I'd suggest you start by editing or checking the material defaults. Select: Edit>Default Settings>Materials Link to comment Share on other sites More sharing options...
robdyck Posted April 22, 2022 Share Posted April 22, 2022 If you want specific help, please post the actual plan. Otherwise, you'll just receive other people's best guesses. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 22, 2022 Share Posted April 22, 2022 I can't tell if that is a shower or a piano. Either way, I think it is going to be difficult to use either inside of a base cabinet. Maybe a pantry cabinet? Link to comment Share on other sites More sharing options...
decorators3 Posted April 22, 2022 Author Share Posted April 22, 2022 thanks all fixed Link to comment Share on other sites More sharing options...
rgardner Posted April 22, 2022 Share Posted April 22, 2022 1 hour ago, decorators3 said: for some reason any objects .. cabinets etc. have an artwork finish that I used on a specific picture .. How do I get back to things back to normal Thanks Levina Are these new cabinets you are placing? If so, see this: 45 minutes ago, robdyck said: There could be several reasons, but I'd suggest you start by editing or checking the material defaults. Select: Edit>Default Settings>Materials If it is existing cabinets in a plan then you probably used the plan or room painter mode when "painting" materials to an existing item. If this is the case then you can select the Material painter tool, you will get a popup asking what texture you want to apply. In that dbx there is the option to use the library or the plan materials on the left. Select the plan materials list and at the very top of that list is Use Default. Select this and make sure you are in Plan apply mode (It should pop up in the edit toolbar (OOB edit toolbar is at the bottom of the window). Now apply that texture on ANYTHING that is showing that material on it. Moving forward I would recommend that you read this article: https://www.chiefarchitect.com/support/article/KB-00793/using-the-different-material-painter-modes.html#:~:text=The Material Painter modes help,material to an object component. Hope this helps. Link to comment Share on other sites More sharing options...
