VVondersaar Posted April 13, 2022 Share Posted April 13, 2022 My engineer can't get the detail he needs from my .dwg file. This is the first CA plan I'm sending to an engineer - I exported from plan view to .dwg keeping the default export settings changing only the version the CE needed. He couldn't use. I tried again changing what layers exported and only exporting one floor at a time - he still can't use. Does anyone have step-by-step instructions or tips that can help? TIA Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted April 13, 2022 Solution Share Posted April 13, 2022 When working with AutoCAD users I send views from the layout page (First floor, Second floor, elevations) and none of them have complained to me about the files. I do NOT use export "All Floors" as that is too complicated for the AutoCAD user to sort out. DJP 1 Link to comment Share on other sites More sharing options...
Doug_N Posted April 13, 2022 Share Posted April 13, 2022 37 minutes ago, VVondersaar said: My engineer can't get the detail he needs from my .dwg file. This is the first CA plan I'm sending to an engineer - I exported from plan view to .dwg keeping the default export settings changing only the version the CE needed. He couldn't use. I tried again changing what layers exported and only exporting one floor at a time - he still can't use. Does anyone have step-by-step instructions or tips that can help? TIA Try posting the plan file, and what specifically your engineer is looking for. What is the objection that the engineer has, just posting that he couldn't use the dwg file is not really explaining the problem. Someone could come up with a useful answer to your question with enough information. Link to comment Share on other sites More sharing options...
VVondersaar Posted April 13, 2022 Author Share Posted April 13, 2022 28 minutes ago, Doug_N said: Try posting the plan file, and what specifically your engineer is looking for. What is the objection that the engineer has, just posting that he couldn't use the dwg file is not really explaining the problem. Someone could come up with a useful answer to your question with enough information. The plan file is too large to upload - any advice on that? As far as I understood from the CE he can't see the wall detail that he needs. He's getting CAD lines, but he isn't getting sufficient detail to engineer the structural members Link to comment Share on other sites More sharing options...
VVondersaar Posted April 13, 2022 Author Share Posted April 13, 2022 30 minutes ago, DavidJPotter said: When working with AutoCAD users I send views from the layout page (First floor, Second floor, elevations) and none of them have complained to me about the files. I do NOT use export "All Floors" as that is too complicated for the AutoCAD user to sort out. DJP Yes the first round I exported all floors and he said that was too much. I then exported floor by floor and now he is saying he isn't getting enough detail for the walls. etc. I'm not at all familiar with AutoCAD so I am a bit at a loss as to what he is getting vs what he needs. Link to comment Share on other sites More sharing options...
MarkMc Posted April 13, 2022 Share Posted April 13, 2022 I do what David suggest, from layout is cleaner. Get a copy of a free CAD program that imports DWG so you can see what they see. I use TurboCad Deluxe which is cheap not free but has some other uses. Link to comment Share on other sites More sharing options...
Doug_N Posted April 13, 2022 Share Posted April 13, 2022 The advantage of exporting from a plan file is that everything is a 1:1 scale. Also the border, title block etc are not exported. It is just a cleaner export for doing CAD work in AutoCAD. Just my 2 cents. Link to comment Share on other sites More sharing options...
Doug_N Posted April 13, 2022 Share Posted April 13, 2022 2 hours ago, VVondersaar said: The plan file is too large to upload - any advice on that? As far as I understood from the CE he can't see the wall detail that he needs. He's getting CAD lines, but he isn't getting sufficient detail to engineer the structural members Send the file through a link to OneDrive, Google Drive or Drop Box, among many methods for sending files too large to upload or send by email As far as the wall detail, is he looking for a plan view of the assembly or a vertical section? Perhaps just making a cad section manually and sending him that would suffice. Link to comment Share on other sites More sharing options...
MarkMc Posted April 13, 2022 Share Posted April 13, 2022 2 hours ago, Doug_N said: The advantage of exporting from a plan file is that everything is a 1:1 scale. Also the border, title block etc are not exported. It is just a cleaner export for doing CAD work in AutoCAD. Just my 2 cents. That is true for plan views, where it gets nasty is elevations get multiple lines layered over each other. At least I've never found a way to get that not to happen, have you? Since I always open dwg files prior to sending the scale is two clicks to solve and border etc a few more so long as layers were exported. To the OP worth checking if they are working on solid black backgrounds, which is very common, and adjust accordingly. Unless your line stiles are all set to Acad colors.Early on I was told a few times that there was nothing there because the lines were all black on black and they didn't select all Link to comment Share on other sites More sharing options...
Doug_N Posted April 13, 2022 Share Posted April 13, 2022 3 minutes ago, MarkMc said: That is true for plan views, where it gets nasty is elevations get multiple lines layered over each other. At least I've never found a way to get that not to happen, have you? Since I always open dwg files prior to sending the scale is two clicks to solve and border etc a few more so long as layers were exported. Lines over lines really don't matter if they are using the dwg file to pick measurements. 3 minutes ago, MarkMc said: To the OP worth checking if they are working on solid black backgrounds, which is very common, and adjust accordingly. Unless your line stiles are all set to Acad colors.Early on I was told a few times that there was nothing there because the lines were all black on black and they didn't select all AutoCAD has a really easy way to change the background colour. Also a pretty good layer management system for changing layer colours. If the AutCAD user can't manage this, I would be questioning the qualifications of the engineer. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 14, 2022 Share Posted April 14, 2022 On 4/13/2022 at 7:14 AM, VVondersaar said: Yes the first round I exported all floors and he said that was too much. I then exported floor by floor and now he is saying he isn't getting enough detail for the walls. etc. I'm not at all familiar with AutoCAD so I am a bit at a loss as to what he is getting vs what he needs. I think you need to get more specific details from your engineer as to what exactly he needs to see. Without knowing exactly what information is needed, you can't possibly know what to export and what not to export. Also, bear in mind that in most cases, you're only going to be exporting what can be seen in your view. If you want to export actual Wall Details then you'll need to open those details and export those individually. As an aside, you can also potentially open a 3D view and export a 3D DWG/DXF file which can be useful to some guys so they can get a better idea of what's going on. Link to comment Share on other sites More sharing options...
VVondersaar Posted May 3, 2022 Author Share Posted May 3, 2022 On 4/13/2022 at 3:09 PM, MarkMc said: That is true for plan views, where it gets nasty is elevations get multiple lines layered over each other. At least I've never found a way to get that not to happen, have you? Since I always open dwg files prior to sending the scale is two clicks to solve and border etc a few more so long as layers were exported. To the OP worth checking if they are working on solid black backgrounds, which is very common, and adjust accordingly. Unless your line stiles are all set to Acad colors.Early on I was told a few times that there was nothing there because the lines were all black on black and they didn't select all I did have the black/black issue once as well. Had me thinking for sure. Link to comment Share on other sites More sharing options...
VVondersaar Posted May 3, 2022 Author Share Posted May 3, 2022 On 4/14/2022 at 1:32 PM, Alaskan_Son said: I think you need to get more specific details from your engineer as to what exactly he needs to see. Without knowing exactly what information is needed, you can't possibly know what to export and what not to export. Also, bear in mind that in most cases, you're only going to be exporting what can be seen in your view. If you want to export actual Wall Details then you'll need to open those details and export those individually. As an aside, you can also potentially open a 3D view and export a 3D DWG/DXF file which can be useful to some guys so they can get a better idea of what's going on. Thanks Link to comment Share on other sites More sharing options...
