AndyRonLI Posted April 4, 2022 Share Posted April 4, 2022 Folks, For small details it is useful to put them on a single 8 1/2 by 11 sheet. I am a returnee to CA and am missing something When I create a new layout it defaults to Arch D When I set the page size to 8 1/2 by 11 and then scale to fit The title blocks and borders are way inside the page edges. Are there layout templates for other sizes? I also cant seem to find the spot to set the scale. or anything but the title I am recalling the layout stuff had the steepest learning curve. Any help is appreciated Thanks ANdy Link to comment Share on other sites More sharing options...
mtldesigns Posted April 5, 2022 Share Posted April 5, 2022 File - Print - Drawing Sheet Setup Link to comment Share on other sites More sharing options...
AndyRonLI Posted April 5, 2022 Author Share Posted April 5, 2022 Micheal, So that's fine to just print it out, but I want an acutal layout with a small title block, the date, page numbers, scale etc etc. The tutorial seems to indicate one can open a truly blank layout and build what I want, but every time I choose new layout I get the ARCH D. I did find some other ARCH sizes. but no ANSI A. Thanks Andy Link to comment Share on other sites More sharing options...
Chopsaw Posted April 5, 2022 Share Posted April 5, 2022 I don't believe there is an Arc A layout template but you can adjust your page size but keep the scale at 1:1 and then create your own title block or edit an existing one to fit on page 0. Once you are happy with the setup save the file as a template. You can actually have several title block templates in the same file but that makes the learning curve even steeper. Link to comment Share on other sites More sharing options...
mtldesigns Posted April 5, 2022 Share Posted April 5, 2022 I was thinking you already had a "A" size border (template). Its real easy to create one, if you don't have one (like Chop mentions). Once that is set, then you can do what I originally suggested to set the size to print. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 5, 2022 Share Posted April 5, 2022 1000 wds- my notes sheet- can be a layout sheet also my 11x17 layout Link to comment Share on other sites More sharing options...
