setting to darken layout
DianeP
I use a separate layer set for sending elevations to the layout, with windows and roofs and walls line-weights set larger than any plan view. This gives it more pop. You can also adjust the actual material line weights as needed
  • Upvote 2
Yep,  this is what I do,  I do not do what Chopsaw does.  Chopsaw's method is not a detailed as Perry's method.
Perry can make the windows line weight 18,  doors 25,  roof 86,  patterns 15........  Chopsaw method limits doors, widows,  roofs to a single line weight.
But whatever works to bring the checks in is all good.  Either method will work.
