DRyeHD Posted January 14, 2022 Share Posted January 14, 2022 I've tried all dbx setting combinations I can think of, looked through the discussion topics, and on the FB user group - can't find a solution to get my balusters to go down to the stair treads. I see a few pictures of this type of application but can't figure out how to do it. I turned the auto-rail off and am using the railing tool. Any help with this is appreciated. Link to comment Share on other sites More sharing options...
DRyeHD Posted January 14, 2022 Author Share Posted January 14, 2022 That's what I need but I can't get it with the stair arrangement I have. I talked to Vince at CA tech support and he said this is a known issue with the Railing and Deck Tools. He added my name to the trouble ticket. The plan file is too big to attach but here is a picture of the stair arrangement. I've had trouble with the wall below the middle rail disappearing and with the the rail coming through the upper platform and railing when I use the "auto" stair rail. Those reasons are why I switched to the desk and rail tool. Link to comment Share on other sites More sharing options...
robdyck Posted January 14, 2022 Share Posted January 14, 2022 On 1/14/2022 at 2:46 PM, DRyeHD said: Any help with this is appreciated. Expand To use a railing wall in that location, you will need to make it a pony wall and then manually adjust the elevation of the lower wall top. 1 Link to comment Share on other sites More sharing options...
DRyeHD Posted January 14, 2022 Author Share Posted January 14, 2022 Robert, thanks for the input. I'll try that when I get back to that project and let you know if it worked for me. Link to comment Share on other sites More sharing options...
Dermot Posted January 14, 2022 Share Posted January 14, 2022 A manual railing set to follow stairs is not able to make the balusters go to each tread. This is a limitation of this tool. A pony wall with a railing will not do this either but will give you a different railing design. If you want to model balusters sitting on top of each tread, you will probably have to turn back on the stair railing or manually place each baluster, newel, and rail. If you are having problems with the stair railing, then you should either post pictures of the problems you are having or post the plan demonstrating the problems (or if all else fails, contact tech support). If you are having problems attaching a plan, you should either zip it to make it smaller or strip out stuff that doesn't affect the problem area to make it small enough to post. 1 Link to comment Share on other sites More sharing options...
DRyeHD Posted January 14, 2022 Author Share Posted January 14, 2022 Dermot, Thanks for the insight. Per Vince at CA, this is a know issue. I will experiment with what works best. This instance is only to try to get the 3D model as close to construction specs as possible - not worth a lot of time spent on it right now. Robert, Thanks also. I'll still try what you've suggested. Link to comment Share on other sites More sharing options...
robdyck Posted January 14, 2022 Share Posted January 14, 2022 On 1/14/2022 at 7:46 PM, DRyeHD said: Robert, Thanks also. I'll still try what you've suggested. Expand Dermot is correct, it won't work. You could use a ramp with the same type of railing. Just make the railing tall enough and bury the ramp inside the wall below. You'll need to manually adjust the slope to match the pitch of your stairs. Now if only a ramp could be dragged to a height in section view... 1 Link to comment Share on other sites More sharing options...
MPDesign Posted January 16, 2022 Share Posted January 16, 2022 Don't stairs cut wall tops? Just use a regular wall type and stair railings. Link to comment Share on other sites More sharing options...
DRyeHD Posted January 17, 2022 Author Share Posted January 17, 2022 Robert, I've not used ramps but your suggestion sounds like a feasible work around. I'll try that. Michael, I need my balusters to extend down to the stair treads. No problem with up. Between Dermont's input and Robert's suggestions, I have a work-around. Thanks. Link to comment Share on other sites More sharing options...
