JGHArchitecture Posted January 6, 2022 Share Posted January 6, 2022 As the title says. with plot lines and color fill selected still getting blurry elevations in my layout file and when I create pdfs. What am I doing wrong??? can't seem to figure it out!!!! Help. Link to comment Share on other sites More sharing options...
Doug_N Posted January 6, 2022 Share Posted January 6, 2022 Holy Cow this looks like a complicated project. Not just for the design, but the construction as well. As for the blurry image, have you updated your PDF printer drivers? Are you using the native CA=> PDF exporter? I use Kofax Power PDF Advanced as my PDF tool of choice (it creates PDFs, edits PDFs, allows signatures, converts PDFs to MS documents etc. I don't experience this problem using that application. Mybe you should post the plan file. The actual PDF output file, and, just beating Solver to the punch here, fill out your signature so that other members can see what version of CA you are using, your hardware, OS etc. It helps us to further diagnose problems and offer better solutions, or (shudder) work-arounds. Link to comment Share on other sites More sharing options...
robdyck Posted January 6, 2022 Share Posted January 6, 2022 Once those are 'broken' they rarely can be repaired. I'd suggest you try to resend that view to layout using your desired settings and see if the new view in layout has the same issues. I'd experiment on a new layout page before I replaced that one. Link to comment Share on other sites More sharing options...
winterdd Posted January 6, 2022 Share Posted January 6, 2022 40 minutes ago, JGHArchitecture said: As the title says. with plot lines and color fill selected still getting blurry elevations in my layout file and when I create pdfs. What am I doing wrong??? can't seem to figure it out!!!! Help. I see this happen with myself if I modify/strecth the terrain after sending my views to layout. Sounds weird but I have nailed it down to that, Link to comment Share on other sites More sharing options...
winterdd Posted January 6, 2022 Share Posted January 6, 2022 32 minutes ago, Doug_N said: Holy Cow this looks like a complicated project. haha right......makes me feel inferior seeing a stepped fdn like that. Glad I live where it is mostly flat. Link to comment Share on other sites More sharing options...
JGHArchitecture Posted January 10, 2022 Author Share Posted January 10, 2022 Thanks for the help. Only way I could get it to work was with live views. Link to comment Share on other sites More sharing options...
Dermot Posted January 11, 2022 Share Posted January 11, 2022 You might want to try deleting the layout box and resending the view. This is kind of a sledgehammer solution but it can often fix a wide variety of layout problems. It's hard to tell by just looking at the small picture but it looks like the color fill is somehow offset from the plot lines. This can sometimes mean that the data saved with the layout box was corrupted in some way. The simplest and fastest way to correct this is just delete the box and resend the view. If the problem happens with a new view sent to the layout box, I would recommend that you report this problem to tech support so that someone can look into this plan more. Link to comment Share on other sites More sharing options...
VHampton Posted January 11, 2022 Share Posted January 11, 2022 Like Rob mentioned, when terrain gets unusually wide, or an errant object is off in the distance somewhere, blurred millwork and fixtures can result. How wide is the terrain? Are there any far away objects which needs to be reeled in so to speak? Something silly like a fixture being placed a few hundred feet away from the model can make this happen. And to piggy back onto Dermott's suggestion, a different/new camera can be a remedy. If that works, after sending a new view to layout, all of the line work (CAD) can be copied and pasted into the new camera. Good luck. Link to comment Share on other sites More sharing options...
