Toolbar Won't Open or Function Properly
ChicByDesign
Go to solution Solved by Kbird1,
A new problem is occurring that I haven't experienced before.  My design assistant was helping me on a project, but we're not sure what we may have done to change a toolbar operation.
Allow me to explain:
In the past:
  • We single click on a toolbar, the box opens on the screen, we select what we want, and we draw
  • For example, adding a wall, we select interior wall, and build
  • Another example, we click the "measure" icon, select point-to-point, and get to work measuring something we need.
Now what happens:
  • We have to double click on a toolbar (single-click does nothing)
  • When we double click, the default settings box appears.  We can't seem to get past this "default settings" box to actually get the toolbar to function!  It's maddening.
What we tried:
  • We went through the process to restore default toolbar settings.
  • This did not fix the problem.  The same "default settings" box continues to appear.
Please see the screenshot of the box that appears when we click on a toolbar:
All input is greatly appreciated!!
Kind regards,
Leigh Ann
Chief Architect x12 user
Hello @solver
Yes, I am expecting to see the individual components of the tool, like you have shown.
In your example, I would select "interior wall" and begin drawing.
But for some reason, it's not working as such.
Instead, the default setting box is the only thing that appears.
Further thoughts?
I an using Chief Architect x12
First, try a reboot.
Did you mess with any of your system settings for your mouse?  You can actually program your mouse to do things like swap the left and right buttons.
Is your mouse battery running low?  Sometimes mice misbehave when battery power is low.
Did you change any of your edit behaviors?  Some tools don't work the same if you are in "alt" mode.
If these don't solve your problem, then you might want to contact tech support.
Double clicking a toolbar button brings up the Default Settings dbx (as you show) - the dbx that opens depends on the state of Edit Active Default On Double Click in Preferences.
This is the correct behaviour.
But your main problem seems to be the single click on the toolbar button.
@Kbird1 That is exactly what must have happened!  Thank you so much!! I wasn't aware of the Child Tool setting and this solved the problem.
@Dermot Thank you for the insight on the mouse.  I'll be sure to monitor the mouse and learn more about the alt mode.
@glennw  Thank you for your response.  I'm somewhat new to Chief and appreciate confirmation that double click brings default settings as correct behavior.
Learning form you all will certainly help expedit my proficiency.  I appreciate your support.
@solver I'm going to review your PM again.  Thank you for posting tips.
    32046
    BDecker
    BDecker
  • Similar Content
    • By limitless8
      So...embarrassed to say this, but I screwed up...Somehow my library catalogs ended up being on top of the screen instead of being to the right...and for the love of god I couldn't figure out how to reset it manually...so I reset the toolbars to default....
      Previously when I would scroll through materials the preview dialog would show them in PBR view...now it's vector or standard, and I don't see the option to have it show in PBR again....and I would love to get that back...any ideas?
    • By tchomes
      This has been an issue with X10, randomly my toolbars will change back to the Drop-Down Toolbars instead of the Parent-Child Toolbars I selected in Preferences.  It probably happens once a week and typically it is after exiting a 3D view.  I haven't been able to trace all the steps, but was going to see if this has been reported or others had the same issue.
      Thanks,
      Roy
    • By mslewis620
      Looking for advice on a complicated remodel. Normally I would set up my floor default then if needed adjust a room or two for ceiling and floor height changes.
      Adding a partial second story to the center section of a house with different ceiling and floor elevations in almost every single room. Some rooms have 8' ceilings, one steps down two steps then has an 11' ceiling another steps down 6" with 9.5' ceilings. There was an addition done at some point that further complicated matters with angles and more steps and ceiling heights.
      To make matters worse, when the living room 19'xwas framed the ceiling must have sagged so the ceiling framing was 2x6 then they put a 16" LVL on top and strapped everything to it with a 2x12 running perpendicular to the whole mess. And that room has the tallest ceiling in the area of the 2nd-story addition.
      Builder prefers to overbuild the entire thing so as not to disturb the electrical, HVAC, etc so it means in rooms with 8' ceilings the subfloor for the 2nd story will be as much as 45" in some areas. It's a large house (6,000SF after) so scale is important to the owner. the rest of the house has a 15/12 roof so the roof is almost overwhelming the house as a single story structure.
      Any of you pros have suggestions I'm willing to listen. Don't want to spend hours setting it up then have it blow up at the end.
    • By djhplanning
      I am struggling to manage my layer sets, annotation sets, default settings and wall definitions.  I have numerous drawing projects going at once (about 12).  Some of them already have different settings.  It seams like every time I work on a drawing project I am always tweaking a layer set, annotation set, default drawing setting or adjusting a wall definition setting on the fly.  What is the best way to manage this so I am always using the most current settings.  If I change a setting in one drawing I am working on, I have to always try to remember to export the updated settings so they are available to import on another drawing.  Do I need to start exporting the settings each time I close a drawing and importing all the settings when I open a drawing file.  Is it possible to just have these settings automatically be used in any drawing file I open (similar to preference settings) without having to import them into the individual drawings.  It seams like there would be no reason to have separate settings for each drawing you work on anyway (unless you have some builder clients with there own graphic standards or something).  If I don't export the settings right away when I make the adjustment, I never know what drawing project has the most recent settings.  Any suggestions as to how to best manage this would be a big time saver.
