SH_Canada Posted October 3, 2021 Share Posted October 3, 2021 I'm trying to add a sunroom to a two storey house. I cannot seem to set the height of the sunroom, without changing the main floor room height. It is repeatable on a test plan. Looks like it is entirely to do with the cantilever on the second floor. If here is no cantilever "inside" the sunroom, everything is fine. Does anyone know how to get around this? thanks Link to comment Share on other sites More sharing options...
SH_Canada Posted October 3, 2021 Author Share Posted October 3, 2021 attached canttest.plan Link to comment Share on other sites More sharing options...
SH_Canada Posted October 3, 2021 Author Share Posted October 3, 2021 bandicam 2021-10-02 19-27-15-829.mp4 Link to comment Share on other sites More sharing options...
glennw Posted October 3, 2021 Share Posted October 3, 2021 If you are going to post a video, please do some narration to explain what is going on. It is just too hard to follow the cursor without narration. 1 Link to comment Share on other sites More sharing options...
SH_Canada Posted October 3, 2021 Author Share Posted October 3, 2021 here is one with a voice over. note the problem does not occur if the second floor cantilever is outside the sunroom. (i.e. if cant is outside the sunroom, when I change the sunroom ceiling height, the main floor height does not change). Not that it matters for the actual problem, but in case someone is wondering why I am doing this, I need the room height to be less so the roof does not hit windows on the second floor. bandicam 2021-10-03 10-54-43-432.mp4 Link to comment Share on other sites More sharing options...
Solution glennw Posted October 3, 2021 Solution Share Posted October 3, 2021 You need to create a room on the upper floor and define the cantilevered area with invisible walls. You can then prevent any changes in the sunroom on the lower floor from changing the height of the main room. Link to comment Share on other sites More sharing options...
SH_Canada Posted October 4, 2021 Author Share Posted October 4, 2021 thanks, that worked! @glennw what your opinion on if this is a bug or not? seems like at a minimum this behaviour, and the workaround, should be documented Link to comment Share on other sites More sharing options...
GeneDavis Posted October 4, 2021 Share Posted October 4, 2021 Doesn't seem buggy to me. All rooms in Chief have some kind of floor, even open below rooms. And we know how a floor above can affect room heights of floors below, don't we? A cantilevered room or part of a room with part of its cantilevered area above a room below (as different from no room below) is going to behave in an unexpected way. We control that with the invisible walls. Link to comment Share on other sites More sharing options...
glennw Posted October 4, 2021 Share Posted October 4, 2021 Not a bug and it is behaving in a totally expected way. That is how I new what to do - not so much by the invisible walls themselves, as gene said - but by the room they create. Link to comment Share on other sites More sharing options...
SH_Canada Posted October 4, 2021 Author Share Posted October 4, 2021 sooo, it looks like it did not quite work for me. now the cantilever portion which is in the sunroom gets built lower than the rest of the cantilever. If adjust the floor for the invisible second storey room, then CA raises the roof of the sunroom. Did I miss something? I changed the color of the siding on the main level to show what is happening canttest.plan Link to comment Share on other sites More sharing options...
glennw Posted October 5, 2021 Share Posted October 5, 2021 I don't have time to have a detailed look at the moment, but you may need to also create a room under the cantilever in the sunroom to get more control. This may be as well as, or instead of the room on the upper floor. Link to comment Share on other sites More sharing options...
SH_Canada Posted October 5, 2021 Author Share Posted October 5, 2021 ok thanks, I'll give it a whirl Link to comment Share on other sites More sharing options...
robdyck Posted October 5, 2021 Share Posted October 5, 2021 On 10/2/2021 at 7:23 PM, jasonN said: Does anyone know how to get around this? You need to break the sunroom into 2 separate rooms to allow for the 2 ceiling heights within that room. No extra rooms needed on the floor above the sunroom. Link to comment Share on other sites More sharing options...
SH_Canada Posted October 6, 2021 Author Share Posted October 6, 2021 yup that worked, no need for the upper room thanks Link to comment Share on other sites More sharing options...
