Tiles disappear off wall when adding dwaf wall in front
gelbuilding
1 hour ago, gelbuilding said:
Chief doesnt like walls next to each other running parrallel.
It's these situations the furred Wall setting is there for , so it may not be working as it should with the new release, you should report it to Tech Support and supply them the Plan.
https://www.chiefarchitect.com/support/article/KB-00181/creating-furred-walls.html
https://www.chiefarchitect.com/support/article/KB-00925/using-marriage-walls.html
Mick.
How would you build it?  Is it actually two walls butted up or a wider stud on the bottom?  Either way, I do this in a bath using a wall definition for both, and setting the wider wall as a pony.  Then a cabinet shelf for the cap.  If its two studs butted up, create a wall def of just that, with a air gap to your liking.
