payettedesigns Posted August 25, 2021 Share Posted August 25, 2021 Do any of you guys ever do a horizontal orientation of your floor plans when 1/4 " =1 ' is to large for a vertical orientation on 24" x36 layout ? Instead of reducing to 3/16" =1' which framers hate? david p Link to comment Share on other sites More sharing options...
Kiwideziner Posted August 25, 2021 Share Posted August 25, 2021 I always draw my buildings so the largest dimension is across the page. It does not really matter the orientation of the layout as long as you a consistant through a plan set. Link to comment Share on other sites More sharing options...
HumbleChief Posted August 26, 2021 Share Posted August 26, 2021 13 hours ago, payettedesigns said: Do any of you guys ever do a horizontal orientation of your floor plans when 1/4 " =1 ' is to large for a vertical orientation on 24" x36 layout ? Instead of reducing to 3/16" =1' which framers hate? david p Yes, whenever "1/4 " =1 ' is too large for a vertical orientation." There's no convention that I'm aware of that requires plans to be oriented 'vertically'. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 26, 2021 Share Posted August 26, 2021 I have a couple of extra Layout Sheet sizes that I use depending on the plan. 24" x 42" 24" x 48" Both of these are custom sizes not provided by standards. I would never use 3/16" scale. If the project is too large for even these sizes I will use a 1/8" scale "Key Plan" and 1/4" scale partial plans. 1 Link to comment Share on other sites More sharing options...
