ACADuser Posted August 14, 2021 Share Posted August 14, 2021 This is a weird one. If I select a lib item from the icon view, insert it, quit the command, I can not select it again from the icon. I'm sure the video will explain it better. I use the ESC key = [Select Objects] to cancel out of the place LIb command. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 14, 2021 Share Posted August 14, 2021 28 minutes ago, ACADuser said: I use the ESC key = [Select Objects] to cancel out of the place LIb command. Try using the Spacebar instead ...puts you back in select mode..... Link to comment Share on other sites More sharing options...
glennw Posted August 15, 2021 Share Posted August 15, 2021 6 hours ago, ACADuser said: I use the ESC key = [Select Objects] to cancel out of the place LIb command. Alan, I am not sure what you mean by this. Esc is usually a shortcut to Cancel Selection/Previous Command - not Select Objects. ESC does default to Selection mode when it has cycled through all the history of commands which makes it look like it is a select tool if you only have one command in the command history list and press ESC once. Or, if you have more that one command in the command history list, repeatedly hitting ESC will cycle back through the command history list. Have you changed any of the keyboard shortcuts lately? Have you closed and reopened Chief? Link to comment Share on other sites More sharing options...
ACADuser Posted August 15, 2021 Author Share Posted August 15, 2021 I use the ESC key = [Select Objects] Don't use the SPACE BAR Link to comment Share on other sites More sharing options...
Kbird1 Posted August 16, 2021 Share Posted August 16, 2021 10 hours ago, ACADuser said: I use the ESC key = [Select Objects] Don't use the SPACE BAR Oh I missed you had changed your Hotkey from default , but If you want to place multiple hangers I see no reason to hit space , you should be able to keep clicking for multiple placements. I can however reproduce the Issue once I hit space ( in my case for select ) the library item is not clickable again, unless you click another item 1st and comeback to your 1st choice. Link to comment Share on other sites More sharing options...
ACADuser Posted August 16, 2021 Author Share Posted August 16, 2021 Ah Ha! So I forgot to add one more hanger & when I went back to get one more Chief refused. Will report this. Link to comment Share on other sites More sharing options...
ACADuser Posted August 17, 2021 Author Share Posted August 17, 2021 Tech support confirmed the issue & turned it overt to software development to fix. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 17, 2021 Share Posted August 17, 2021 19 minutes ago, ACADuser said: Tech support confirmed the issue & turned it overt to software development to fix. Thanks for the Report Back Alan, good to know. M. Link to comment Share on other sites More sharing options...
Oakriverman Posted August 17, 2021 Share Posted August 17, 2021 I am running into this. If I select a different icon and then select the one I am using again it works. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 17, 2021 Share Posted August 17, 2021 1 hour ago, Oakriverman said: I am running into this. If I select a different icon and then select the one I am using again it works. You should send in a report as well if you care enough to see it fixed. Link to comment Share on other sites More sharing options...
ACADuser Posted August 17, 2021 Author Share Posted August 17, 2021 2 hours ago, Oakriverman said: I am running into this. If I select a different icon and then select the one I am using again it works. That was the recommendation from tech support until they fix it. Good advice from Michael, the squeaky wheel as they say. Link to comment Share on other sites More sharing options...
