Gawdzira Posted June 22, 2021 Share Posted June 22, 2021 Uhhh, why? There is not one spot where it aligns. Any ideas on how to get this to look better? OOB beige standing seam texture from CA. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted June 22, 2021 Share Posted June 22, 2021 Maybe that's a "feature" so you can distinguish the roof planes?.............NOT! Sorry, just needed a little break from reality. Link to comment Share on other sites More sharing options...
robdyck Posted June 22, 2021 Share Posted June 22, 2021 3 hours ago, Gawdzira said: Uhhh, why? There is not one spot where it aligns. Any ideas on how to get this to look better? OOB beige standing seam texture from CA. Interestingly enough, rotate the texture and pattern 90 degrees and see what happens. Link to comment Share on other sites More sharing options...
glennw Posted June 23, 2021 Share Posted June 23, 2021 The only way I know to line up a pattern or texture between 2 roof planes is to uncheck Global Symbol Mapping and then create a copy of the roof material for each roof plane. You can then use the material's Horizontal Offset to move the pattern or texture. But...you will never be able to go around all of the roofs and line the all up unless you layout your roofs with regard to the spacing of the standing seams. Link to comment Share on other sites More sharing options...
