Can't edit lines in layout
dbcaceresr
Is it in a plan view? or a plot line view?
IF it's a live view either set "update always" or update on demand, then you won't be able to.
Otherwise post an example of layout with plan OR screen shots showing dialog box
Sometimes I have to shift select while using the 'edit layout lines' tool to activate some lines.
If you have overlapping viewports, the lines will be unselectable.  You can pull one viewport back to slect the lines.
