Roof Issue
fcwilt
It looks like you may have turned auto roof off a bit too soon.  If you are doing manual roof you are on your own to make it work out but hard to say exactly what the issue is without a plan file but it looks as though the soffit is manually following the roof surface layer which does not always work out properly on a custom build.
5 hours ago, fcwilt said:
Hi,
Can someone explain what is causing this?
Can it be fixed?
Thanks.
It is being caused by the gable fascia being deeper than the eave fascia . Chief builds soffits to follow the roof plane and doesn't treat them as separate objects. A boxed eave (not flush eaves) can be used, but if that isn't desired, you'll need to manually build your soffits using solids, moldings, or ceiling planes.
That makes sense. I think I can sort it out.
Thanks.
