mulligan Posted April 17, 2021 Share Posted April 17, 2021 My engineer has requested that I provide a specific detail for a roof beam and bracket that I haven't created in the past. I have created a CAD detail from a view of the elevation and I would like to add some additional detail components to the specific view without using the entire elevation. I know that I can redude the layout box to whatever area I want, but if I do that it will also my callouts to the layout box. Is there a way that I can CAD detail from view, then outline the area that I would like the detail for and delete the rest/ Which would then allow me to add callouts. I know this may sound confusing so I have attached a screed shot of what I would like to accomplish. Thanks in advance for any suggestions. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 17, 2021 Share Posted April 17, 2021 Yes those are all just cad lines so they can be deleted or trimmed back to where ever you like with the cad tools that are available. Saves a bit on memory as well if you do that. Link to comment Share on other sites More sharing options...
mulligan Posted April 17, 2021 Author Share Posted April 17, 2021 Thank you solver, the clip to sides does work. Any suggestion on the elevation? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 17, 2021 Share Posted April 17, 2021 2 minutes ago, mulligan said: Thank you solver, the clip to sides does work. Any suggestion on the elevation? X13 Link to comment Share on other sites More sharing options...
mulligan Posted April 17, 2021 Author Share Posted April 17, 2021 I guess I can just manipulate the layout box for the elevation. Link to comment Share on other sites More sharing options...
mulligan Posted April 17, 2021 Author Share Posted April 17, 2021 Thanks Chopsaw may need to upgrade. Link to comment Share on other sites More sharing options...
mulligan Posted April 17, 2021 Author Share Posted April 17, 2021 YES thank you solver that is absolutely the easiest way,, because I can manipulate it however I want! Always appreciate your help! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 18, 2021 Share Posted April 18, 2021 I typically handle these types of things 1 of 4 ways depending on the situation: If I want (and am able) to keep the view live I will do as @solver suggested and simply mask it with a filled polyline. This crops the view, allows for the desired annotations, and is definitely the most desirable approach whenever it can reasonably be applied.. I will create a CAD Detail From View and use the CAD mask there. Don't think I do this very often though. I will create a CAD Detail From View and just delete/trim line work as @Chopsaw suggested. If I'm creating a CAD Detail from View for the purpose then this is usually how I crop things. I'll write up another post in a minute describing a pretty quick method of speeding this process up. I will crop and annotate in Layout. This I also do pretty rarely but its definitely something I do from time to time for various reasons. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 18, 2021 Share Posted April 18, 2021 How to quickly crop CAD Detail linework... https://rumble.com/vfrqr3-quickly-cropping-cad-detail-from-view-in-chief-architect-x12.html 1 Link to comment Share on other sites More sharing options...
joey_martin Posted April 20, 2021 Share Posted April 20, 2021 FWIW...I would keep this live and model the area like I want it built. Live details and sections are easy to do and you don't end up fighting all those CAD lines. My layout view... When you click on a detail... Just crop them down on the layout page. Link to comment Share on other sites More sharing options...
SH_Canada Posted April 21, 2021 Share Posted April 21, 2021 13 hours ago, joey_martin said: FWIW...I would keep this live and model the area like I want it built. Live d Joey, Are you doing this by maintaining the text, leader lines, and background and then placing on each section, for each plan, in lieu of canned CAD blocks? this would mean for each roof pitch, you are adjusting the labels for truss/wall detail? Link to comment Share on other sites More sharing options...
joey_martin Posted April 21, 2021 Share Posted April 21, 2021 All my notes, fills, roof pitch markers, etc are in my library. Drag and drop. EDIT: I will add that. I have "canned details" in my library, but by the time you drop those, explode them so that they can be adapted for the specific project, and then added to the layout page, I can do details just as fast this way and I don't want/need hundreds of details floating around and clogging my library. Faster, for me, to model accurately and drop my notes and fills and move on. I have a 3/4"=1' annotation/layer set so one click, a few drag and drops and detail done. Link to comment Share on other sites More sharing options...
