ChiefuserMathews Posted March 20, 2021 Share Posted March 20, 2021 In my plan, in one room there is a room label without any room dimension. Is there a way to find out where is it and why it is generating without any room dimension? (screen shot attached) Link to comment Share on other sites More sharing options...
Chopsaw Posted March 21, 2021 Share Posted March 21, 2021 Maybe try creating a Room Schedule and use find in plan or check that three way wall intersection with the two different wall types. Invisible room divider ? Island room ? Short of that.... Post the plan and let one of the experts play. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 21, 2021 Share Posted March 21, 2021 Just a guess without the plan, but I'm thinking you probably have a room defined right here.... Link to comment Share on other sites More sharing options...
mtldesigns Posted March 21, 2021 Share Posted March 21, 2021 Or, you had this defined as a bedroom, deleted a section of wall where it was no longer a room.. but the label stayed. (has happened to me). The when you created the room again, a new label came in. Delete both labels, and check that room DBX. The other way is they way Chop explained. Create a room schedule, and find it via that. Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted March 21, 2021 Author Share Posted March 21, 2021 Thank you all for your response. I tried all the suggestion still it pops back again. Plan attached 221007.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 21, 2021 Share Posted March 21, 2021 Your problem areas are right where I showed. You have little tiny rooms generating between those walls. There are a few potential solutions but I would suggest in particular that you read up on the Furred Wall setting. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 21, 2021 Share Posted March 21, 2021 By the way, that little zero area room can be any number of shapes and can be hard to fish down because not only can it be connected to any number of surrounding rooms but it can also get its name from any one of the connected rooms. This is where your particular problem room is being generating and its simply getting its name from the adjacent bedroom in the corner... That one isn't the only problem your in your plan though. You have another one over on the left side, it just has the room label suppressed. Plus you have a 3rd one that is being considered part of another room.Try moving the indicated wall down, select the resulting room, and notice how its shaped... Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted March 21, 2021 Author Share Posted March 21, 2021 Thank you all for your comments and tips. I will combine them. In reality the foundation wall is built and that basement area is being converted into a living space, hence the stud wall added. Concrete foundation wall is the as built condition. Thanks again. Link to comment Share on other sites More sharing options...
