ACADuser Posted December 1, 2014 Share Posted December 1, 2014 How do you handle this condition. I want hidden walls to be visible to me while working but some I don't want to print. What I want is a non printing layer for some walls. Link to comment Share on other sites More sharing options...
HumbleChief Posted December 1, 2014 Share Posted December 1, 2014 You could create a printing Anno Set, and a working Anno Set, but I don't think there's a way to set up individual layers to print/not print. That would be a great feature IMO. Link to comment Share on other sites More sharing options...
rlackore Posted December 1, 2014 Share Posted December 1, 2014 You can have invisible walls "visible" in plan, then when you send to layout choose "Make a Copy of Active Layer Set" and turn off the Walls, Invisible layer in the layout layer set. However, if you want them visible in layout, but not print - I don't think that is an option. I would love to see a tickbox in our layerset manager that allows for layers to be no-print. This should be a basic feature of layer management. Another work-around may be to use a slightly off-white background, set your invisible walls to use a white color, then when you print from layout the white lines won't be visible. Just a thought. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 1, 2014 Share Posted December 1, 2014 I just put them on another layer and turn them on and off. Link to comment Share on other sites More sharing options...
ACADuser Posted December 1, 2014 Author Share Posted December 1, 2014 Yea, another work around. 1 Link to comment Share on other sites More sharing options...
RodCole Posted December 1, 2014 Share Posted December 1, 2014 There are a lot of advantages to having a second view sent to layout for your working settings when you return to the plan. The advantages of the working view far outweigh the extra time it takes to set it up IMO. No need to have anything showing in the Layout for the working set. Just adjust the layout view border so that nothing is showing in the layout. You can also place them on a separate layer and turn the borders off using a Layer Set in Layout. You can actually set up any number of these working views. That way you can display the plan as you want, and have preset working environments as well that automatically call anno sets and layer sets. I use the Layout as sort of a Dashboard for displayed views and working view sets. Link to comment Share on other sites More sharing options...
