Designer1
Half hot recepticle?
Does anyone know where this might be in Chief?  Im having a hard time finding this in the library.
Thanks in advance!
type in split wired in your browser.    I'm assuming this is what you meant.
Thanks Michael, yes thats what I was talking about.  The Arch firm I use to work for called it that, wasnt sure what the name was in chief.
Thanks again for the help!
Switched is the term I have been using.
Around here, when when an outlet is switched it's "upside-down" so that the resident can tell that outlet is switched.  But I think it's usually both of the outlets, not just one of them so it wouldn't be "Split Wired" - just a standard duplex upside down.
"Switched" to me has always meant half, and the usage has always been nightstand lighting in bedrooms.  If both were switched it would fiddle with your clock radio, or your charge jack.
Makes sense.  I guess I just need to determine which outlet is supposed to be switched (top or bottom of the inverted duplex)
    29351
    LawrenceG
    LawrenceG
