Darrellx Posted February 24, 2021 Share Posted February 24, 2021 I'm using home designed pro 2021. Circled in the picture below is the area unfilled between the lower and upper roof where there is no wall. I can extend the wall inward toward the peak to close the gap, but then area below the gap is closed off. I've experimented, googled, and watched a bunch of video tutorials on roofs. Actually seemed like one of the tutorial videos had a similar issue, but the instructor kinda glossed over it and changed to pitch on one roof to make it look a little better before moving on. After banging my head for a few days, hoping someone has the answer. (plan is also attached for the image) MissingGableWall.plan Link to comment Share on other sites More sharing options...
glennw Posted February 24, 2021 Share Posted February 24, 2021 1 hour ago, Darrellx said: I can extend the wall inward toward the peak to close the gap, but then area below the gap is closed off. Extend the wall towards the ridge and then look up "Roof Cuts Wall At Bottom". Link to comment Share on other sites More sharing options...
Darrellx Posted February 24, 2021 Author Share Posted February 24, 2021 Thanks Glenn, that solved it about 96%.and closed most of the hole up while leaving the interior clear. One thing, even after moving the second section of the wall well past the ridge w/ "cut at bottom", I see a little flaw in the wall above the ceiling on the exterior: Any way to easily fix this (updated plan attached)?...now that I know how to make it really good, I'm wondering how to make it perfect:) AfterCutAtBottom.plan Link to comment Share on other sites More sharing options...
SNestor Posted February 24, 2021 Share Posted February 24, 2021 @Darrellx - made you a quick video. Darrelx - Dormer Cheek Wall Issue — Watch Video 2 Link to comment Share on other sites More sharing options...
Darrellx Posted February 24, 2021 Author Share Posted February 24, 2021 That's perfect! So I see the "trick": 1) The automatic attic wall wasn't extended close enough to the ridge (I manually edited the attic floor plan to get the same effect as you dragging in the 3D rendering). In either case, this requires disabling (via dialog question when changing) automatic wall generation for that particular wall. 2) The "roof cuts wall at bottom" needs to also be enabled for that attic wall (in addition to enabling it for an extension of my original exterior wall in my first plan with the full gap). Thanks for the video...moving pictures worth millions of words! I think Chief Architect could use a whole video tutorial on "when walls go wrong". Link to comment Share on other sites More sharing options...
Doug_N Posted February 24, 2021 Share Posted February 24, 2021 Steve, great video. I have had than problem lots of times and solved it by deleting and stretching walls, but your solution is very elegant. 1 Link to comment Share on other sites More sharing options...
SNestor Posted February 25, 2021 Share Posted February 25, 2021 7 hours ago, Doug_N said: Steve, great video. I have had than problem lots of times and solved it by deleting and stretching walls, but your solution is very elegant. Thank you Doug... Link to comment Share on other sites More sharing options...
