Adding a center rail to a cabinet door
RSdesignvt
Hi all,
Chief Architect V12 Premier
Most cabinet manufacturers along with custom cabinet makers will not make a cabinet door over a certain height without adding a center rail. I am looking for a way to add a center rail to a cabinet door. Additionally I would also like the option if I did this to an upper cabinet door over a certain height that I can make the upper portion glass.
Custom door needed for either way, whether one panel glazed or both solid.
You'll use one or two sets of horizontal stretch planes, depending on the result you want.
Write a suggestion for Chief to add this option.  Chief seems to like cabinet stuff, and you might get it for 2022.
