EDCsharon 0 Posted January 15 Hi all, Chief Architect V12 Premier Most cabinet manufacturers along with custom cabinet makers will not make a cabinet door over a certain height without adding a center rail. I am looking for a way to add a center rail to a cabinet door. Additionally I would also like the option if I did this to an upper cabinet door over a certain height that I can make the upper portion glass. Share this post Link to post Share on other sites
rgardner 164 Posted January 15 Simple double door use one from the library (chief has a double door library) the one with the top only being glass would be a custom door. Share this post Link to post Share on other sites
GeneDavis 144 Posted January 16 Custom door needed for either way, whether one panel glazed or both solid. You'll use one or two sets of horizontal stretch planes, depending on the result you want. Write a suggestion for Chief to add this option. Chief seems to like cabinet stuff, and you might get it for 2022. Share this post Link to post Share on other sites
rgardner 164 Posted January 16 1 hour ago, GeneDavis said: Custom door needed for either way, whether one panel glazed or both solid. Not for the double panel solid unless one of these doesn't meet your needs. Share this post Link to post Share on other sites
EDCsharon 0 Posted January 18 Ryan Thank you! I'm very appreciative for the help! Share this post Link to post Share on other sites
MarkMc 541 Posted January 19 On 1/15/2021 at 3:29 PM, EDCsharon said: I am looking for a way to add a center rail to a cabinet door. I updated the plan file I posted over here for making cabinet door symbols Added a double and the parts, took 10-15 minutes. Once you have a small collection of wainscot panels and framing bead profiles doors are a snap. Share this post Link to post Share on other sites
