Easy Plan sketch software
Jones_Drafting
Hi,
I'm working more remotely these days, and have had some guys help in gathering dimensions and property information.
While I've become practiced in sketching out the layout of a typical 2000sf house, I guess it does take a little practice.
Trying to make this process simpler, I'm looking to see whether anyone could suggest easy, straightforward software which will run on a tablet or i-pad, with which someone could easily draw walls, add windows and doors, pull dimensions....doesn't have to be fancy, just able to record accurate dimensions....thinking via touchscreen would be best....
Suggestions which don't require much of a learning curve?
Thanks!
1 hour ago, Jones_Drafting said:
Heh...yep...I figured out a way to mount a table to the top of my camera tripod.
Works great. People go, "Ooh!" too. :)
Think I found something in magic plan for apple or android devices...
Just downloaded it to give it a spin.
Thanks!
pretty sure magicplan will do it with a lidar scanner for the new iphones and ipads.  But just like any scanning make sure you either take some key dimensions or use a second source like hover.to for backup information.
