wjmdes Posted January 4, 2021 Share Posted January 4, 2021 What I am trying to duplicate... I removed the casing and my result is... I have tried different combinations and I know I have done this in the past, just cannot find that project. I'm sure it is a toggle I am missing. Any thoughts. Link to comment Share on other sites More sharing options...
joey_martin Posted January 4, 2021 Share Posted January 4, 2021 Window recessed to sheathing layer. 2" sash setting, 2" frame setting. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted January 4, 2021 Share Posted January 4, 2021 What is missing is your plan file so we can examine your window specs. Link to comment Share on other sites More sharing options...
joey_martin Posted January 4, 2021 Share Posted January 4, 2021 P.S. If the wall is solid masonry, you will need to eliminate the rough opening settings. The gap you see is probably the rough openings, but there isn't framing in a solid masonry wall. 1 2 Link to comment Share on other sites More sharing options...
wjmdes Posted January 4, 2021 Author Share Posted January 4, 2021 2 hours ago, joey_martin said: P.S. If the wall is solid masonry, you will need to eliminate the rough opening settings. The gap you see is probably the rough openings, but there isn't framing in a solid masonry wall. This was the issue! Thank you! Link to comment Share on other sites More sharing options...
ChiefWA Posted November 6, 2022 Share Posted November 6, 2022 On 1/5/2021 at 6:19 AM, wjmdes said: This was the issue! Thank you! Where is the setting to remove the rough settings? Link to comment Share on other sites More sharing options...
DBCooper Posted November 6, 2022 Share Posted November 6, 2022 Window dialog (or defaults), rough opening. You might also need to check the add for concrete cutout setting too. Link to comment Share on other sites More sharing options...
