Attic wall clipping window top
BnCKelley
Looks like the window is higher than your ceiling height for that room.  Could be an attic space with slopes ceiling which if that is the case you would be balloon framing that wall as Perry’s mentions and that should make it fix if you change it to that.
35 minutes ago, BnCKelley said:
Not sure how to do the balloon framing. There's no ceiling in the attic, it's just open space. Thanks
If there is no ceiling, the balloon through option frames from the floor plate through where the normal ceiling plate would be to the under side of the roof framing.
