BnCKelley 2 Posted January 1 happy New Year everyone, would anybody out there know why this is happening to the top of my window? I was curious if it's because it was an attic wall. Share this post Link to post Share on other sites
DRAWZILLA 784 Posted January 1 try to rebuild the attic wall or make the main wall balloon frame. I like to leave auto rebuild walls on until I need to turn it off.. Share this post Link to post Share on other sites
rgardner 163 Posted January 1 Looks like the window is higher than your ceiling height for that room. Could be an attic space with slopes ceiling which if that is the case you would be balloon framing that wall as Perry’s mentions and that should make it fix if you change it to that. Share this post Link to post Share on other sites
BnCKelley 2 Posted January 1 Not sure how to do the balloon framing. There's no ceiling in the attic, it's just open space. Thanks Share this post Link to post Share on other sites
Doug_N 61 Posted January 1 35 minutes ago, BnCKelley said: Not sure how to do the balloon framing. There's no ceiling in the attic, it's just open space. Thanks If there is no ceiling, the balloon through option frames from the floor plate through where the normal ceiling plate would be to the under side of the roof framing. Share this post Link to post Share on other sites
