Perspective view & Elevation view not showing correctly
capitaldesigns
The last update was in July 2020. Recently I have been having a problem printing Chief drawings with my HD plotter. The plotter would print a couple of sheets and then stop in the middle of the next sheet. Last week I called tech. support. He took over my computer for about a half hour while he resolved the problem. I was told that when I send a sheet to the plotter and tell it to make 3 copies Chief send that sheet 3 separate times. If the drawing is a large file it will lock the plotter up. When printing large drawing files I need to make one copy at a time in order to not lock the plotter up. I have had the plotter for about a year now. It had never done that before until the last few weeks.
I don't know if this has anything to do with the grainy elevation and perspective views.
Maybe check in Preferences to see what the Video Card Status says and make sure it is using your main video card.
Not sure how the printer issues could be related but maybe if they both somehow use the same ram memory and there is now an issue.
Might be one for tech support or a hardware guru.
This is a screen shot with the video card information on the right. I no I have a GeForce graphics card in this computer. It shows in preferences that it is an
Intel UHD Graphics 630. I don't know what that means and why it's not showing the GeForce graphics card. I will call HP tech. support in the morning to find out if they changed my graphic card settings. If not I will call Chief tech. support.
All other graphics on my computer look normal and have not changed. Even the back drops in Chief look normal. The only thing that has changed is elevation and perspective views. See attached.
Ok that is it then.  Others have had that issue so it should be searchable here on the forum but never done it myself.
Your laptop is just using the basic integrated video card so it just won't render the complicated stuff that chief requires.
There are a few different ways to deal with this.  Windows 10 has a built in feature though.  Try this...
Go to Settings>System>Display, go down to the bottom of that page and click on Graphics Settings.  Under "Choose an app to set preferences", select Desktop App and then click Browse.  Go to Program Files>Chief Architect>Chief Architect Premier X12 and scroll down to Chief Architect Premier X12.exe.  Select that .exe file and click Add.  Now click Options and select High Performance.
Just tried Alaskan_Son's instructions. I got as far as the Graphics Settings then choose an app to set preference. I do not see the "Desktop App" in the pull down menu. I see "Classic App" and Universal App" see my screen shot. When I select "Universal App" I get another pull down menu below that says "Select an app".
Under that pull down list I do not see Chief Architect in the list. See screen shot.
I'm not sure how to get Chief Architect to show up in this list.
Everything has been working fine until recently. Yesterday is the first time I ran an elevation view in the last week or so. I have not change anything or added any new programs on the computer for several months. Last week HP Tech. support took remotely took control of my computer to resolve a plotter issue. They might have changed some settings that I was not made aware of.
Have a look here I re-wrote and old post and put it in the Tips Sections ..........
8 hours ago, capitaldesigns said:
Did that and re-started computer and still have grainy elevations.
Attached is a screen shot of the graphic settings.
I will need to look at this on Wednesday. Everyone is waiting for me. We are going to Laughlin, NV for a couple of days.
Thanks,
Mike
You have to follow the instructions all the way through to the end...
20 hours ago, Alaskan_Son said:
...click Options and select High Performance
