BnCKelley 2 Posted December 16, 2020 How can I "turn off" everything below my terrain (top of grade) in the auto elevations. I've been reading for 30 minutes and can't find it. Thanks Share this post Link to post Share on other sites
joey_martin 389 Posted December 16, 2020 I use a layer set (ELEVATIONS, EXTERIOR) and the layer WALLS, FOUNDATION is set to light gray and dashed to achieve this.. If you don't want anything showing, put a thick "grade line" on your elevation and after sending it to layout, pull the view window up to the line... 1 Share this post Link to post Share on other sites
Chopsaw 655 Posted December 16, 2020 You can also turn off the ones you will never use in defaults or pull them off if it is just a particular view you are concerned about. Nice job on the foundation walls Joey. 1 Share this post Link to post Share on other sites
joey_martin 389 Posted December 16, 2020 Working up a daylight basement set now. Foundation walls use my layer settings. Share this post Link to post Share on other sites
dshall 1512 Posted December 16, 2020 15 hours ago, joey_martin said: Working up a daylight basement set now. Foundation walls use my layer settings. 2 questions: 1- now why do I not see the stone below grade? 2- why is wall below grade dashed but the line of wall above grade solid? Share this post Link to post Share on other sites
NRST8TRKR 28 Posted December 16, 2020 I'm guessing ,pony walls Share this post Link to post Share on other sites
joey_martin 389 Posted December 16, 2020 1 - The stone is applied using a wall material region...just as it would be with this type of cultured stone....so I am able to manipulate the bottom edge to follow the terrain. 2 - Pretty much the same as above. When veneer is applied using the wall material region, it "hides" the foundation wall below it so that I can use my WALLS, STONE VENNER layer to control the line type and weight. Share this post Link to post Share on other sites
joey_martin 389 Posted December 16, 2020 Just now, NRST8TRKR said: I'm guessing ,pony walls Nope. Share this post Link to post Share on other sites
dshall 1512 Posted December 16, 2020 1 minute ago, joey_martin said: 1 - The stone is applied using a wall material region...just as it would be with this type of cultured stone....so I am able to manipulate the bottom edge to follow the terrain. 2 - Pretty much the same as above. When veneer is applied using the wall material region, it "hides" the foundation wall below it so that I can use my WALLS, STONE VENNER layer to control the line type and weight. That is what I would of guessed. I am not sure I would dash the walls. I like the way you "hugged" the terrain close to house so as to hide some of foundation wall, but to avoid the hassle of manipulating the "SOLID" lines above grade, I would leave them solid above and below grade. Since you are using the color of the foundation walls, I would leave the lines solid. The use of the terrain is very nice. I am so into editing as little as possible... if it was real stone, it would be below grade sitting on some sort of a footing.... if it was applied phony stone..... it is typically stopped at the stucco street. (above the terrain).... just thinking out loud 1 Share this post Link to post Share on other sites
