EngelsmaHomes 6 Posted December 11, 2020 Hi All, Is there a way to recess corner boards (similar to the recessing doors and windows to the sheathing layer) like you would do for James Hardie siding or similar? Thanks, Tom E. Share this post Link to post Share on other sites
Kbird1 822 Posted December 11, 2020 No, not automatically but it has been Requested as a Change I believe. M. Share this post Link to post Share on other sites
NRST8TRKR 28 Posted December 11, 2020 I set my Corner Boards at 1/4" thick. Looks closer to normal,not that much trouble. Have a great week end, Ken Share this post Link to post Share on other sites
EngelsmaHomes 6 Posted December 17, 2020 On 12/11/2020 at 12:58 PM, Kbird1 said: No, not automatically Is there a manual way? On 12/11/2020 at 3:06 PM, NRST8TRKR said: I set my Corner Boards at 1/4" thick. Looks closer to normal,not that much trouble. Thanks Ken. I'll have to do this as a workaround - it's inaccurate in a plan view still though so I was wondering if there was a more correct way. Share this post Link to post Share on other sites
GeneDavis 142 Posted December 17, 2020 HardiePlank is 5/16" thick and laid up it's closer to 3/4" at max, so that's how I've set it in the wall build. We use cornerboard at 5/4 thickness (1") and since Chief places cornerboards ATOP the siding, I specify the CBs at 1/4". If you prefer a "flush" look then go with 1/16" over whatever you've set for siding, to avoid z-fighting. We won't do "flush" because it won't permit well-caulked joints where claps resolve into trim. Share this post Link to post Share on other sites
Chopsaw 658 Posted December 17, 2020 57 minutes ago, EngelsmaHomes said: I'll have to do this as a workaround - it's inaccurate in a plan view still though so I was wondering if there was a more correct way. If you want it to show correctly in plan view use a p-solid with solid fill. Share this post Link to post Share on other sites
GeneDavis 142 Posted December 17, 2020 Trim's applied to sheathing not framing. Share this post Link to post Share on other sites
Chopsaw 658 Posted December 17, 2020 Thanks Gene, That was just a quick demo but I knew something seemed a bit off. See Revised. Share this post Link to post Share on other sites
EngelsmaHomes 6 Posted December 17, 2020 2 hours ago, Chopsaw said: If you want it to show correctly in plan view use a p-solid with solid fill. Thanks Chopsaw. Share this post Link to post Share on other sites
