holdowns
sunnyseven
I have a question for an architect out there who is familiar with CA building codes. I'm planning using concrete block for the exterior walls of a house. I'm figuring on digging some footings, building the exterior walls, then pouring 4" of concrete for interior floors. What I'm wondering about is interior walls. Should I be planning on footings underneath all the interior walls? If so, is it typical to place threaded rod in those footings that will extended up through the slab in order to anchor the interior walls. I'm sure some of those walls will be structural when it comes to the roof. I've built structural slabs before, which would resolve the issue, but in this instance I don't want the elevation gain.
Thanks,
Tom
I'm building in California, on the side of a mountain. I suppose the abbreviation CA could mean Canada as well, although I wasn't aware of that.
So when you put a footing under a load bearing interior wall, do you preset threaded rod in the footings so they can grab the bottom plate that sits on the slab? I'm thinking the footings would be below the slab, which would be done in a monolithic pour, for convenience sake. I know we're not allowed to wet set foundation bolts but I've never seen what I'm talking about done before.
I'm in California and we wet set anchors on every job. you really should wet set all holdowns bolts also, although you can drill them in after, You will need a special inspection with each hole you drill --costly.
  • 1 month later...
It sounds to me that you first need a plan including architectural design, structural design, energy compliance etc.
Once those decisions are made, then you will know where your bearing walls and shear walls are.  This will determine all your footings and hold downs.
All hold downs and anchor bolts in California, must be in place for the pour.  It does make finishing more difficult.
As said above you can drill and epoxy threaded rod after with a special inspection.  You could also check out Simpson titan bolts for wood plates.
I am curious, why you are using CMU's?  How do you plan on achieving  your insulation values?
Hi Tom,
Just saw this. I'm not here as often as I used to be. But, some general thoughts are below.
First, for interior slabs, I certainly wouldn't use less than 5" and 6" would be better. 4" is a pretty chintzy garage slab, and likely to crack. I'd use #3 rebar, say at 12" E.W., rather than WWF. If walls are not loadbearlng or designed for shear, they don't need thickened footings beneath them, and don't need preset anchors or drilled expansion bolts. Powder-driven pins would be the typical way to secure these to the slab. In a nutshell, I highly recommend getting your structure fully engineered based on actual soil conditions and local seismic/wind values. HTH...
