decorators3
rendering
Hi
Can you tell me if backdrops make a difference in  rendering quality and time..
is it better to have backdrop or not.
when I import street view will  it interfere with my ray trace or PB rendering
Thank you
I will volunteer my thoughts on backdrops in ray
traced renderings. Backdrops in PBR's behave
entirely differently and can cause unexpected
effects on the outcome.
Backdrops certainly make a difference in ray trace
quality but have very little effect on rendering time.
They are after all just image files. The higher the
quality of the image you turn into a backdrop, the
better it will look in the rendering.
To have a backdrop or not will depend on your
intended results. If it's just the view out of an
unimportant window in an interior scene, maybe
a backdrop will just be a distraction from your
intended focus. In other cases the background
is everything. As below. B)
Plan View
corresponding Ray Trace
hanks for your reply.. your space man without the backdrop would not have the same visual effect for sure!
I am currently working on a house exterior and plan on implementing it into the street view so client can see is house in comparison to his neighbors.
So what your saying is in RAY TRACE  the backdrop (if a quality image) will affect the quality of the overall rendering but not take up any additional time .  unfortunately I can't  use  material definition on the backdrop if it is not of good quality
again it is a matter of choice
can you tell me if there is a specific way to get quality street views into CA for backgrounds
Thanks
Levina
I have always used a third party program to do photo montages.
I don't think you can get a good 3D effect by only using a background.
This is a very old one.
Hi Levina. What the little green guy is showing
is the effect the backdrop can have on the model.
In that plan we have the model (in this case the
saucer) and no other objects. The saucer has a
100% reflective surface but there is nothing else
in the plan to reflect except what might be in the
backdrop. Everything that is showing on the skin
of the UFO is a reflection of what is in the backdrop.
It's interesting that the reflected effect wraps all the
way around the saucer like a Spherical Panoramic
View even though the backdrop is flat.
Anyhow, in the situation you describe the challenges
will vary depending on the type of view you are
creating. But whether it be an overhead or street
level view the process involves getting a good quality
photo of the existing situation from the viewpoint you
want and then recreating that viewpoint in the camera
view in your plan. As Glenn mentions above (nicely
done BTW) it helps to have an image editing software
program to tweak your backdrop image to suit your
needs. Once you have an image you want to use for
the backdrop open your Library Browser and right
click on your User Catalog. Then go to New and then
Backdrop to add your image to the list of backdrops
you can choose in the camera specification DBX. Of
course there are many other considerations to deal
with such as matching the sun angle shadows and
how much, if any, of Chief's terrain to include and how
it blends into your backdrop image.
Good Luck, hope this gets you started.
Nicely done Glenn. Though a backdrop is a pic there's a big difference when the model is incorporated into the pic versus just being in front of the pic. To obtain the former you will need to utilize other software to accomplish this. My example below was done using Photoshop, the CA render was cropped to isolate the structure and added as a layer over a real pic of the site. The model layer was then manipulated in an attempt to match the angles and perspective of the site pic, not perfect but much better than anything that I could have done is just using CA. What's also interesting is that this CA render on it's own looked much less real than after placing it into a real pic. It does beg one to seriously consider whether CA's difficulty in producing convincing renders is related to lighting or just the fact that the symbols we have are just too basic and no matter how well you try to light them they will never look real.
Here's another example just using a google street view rendered in CA. The google street view was first loaded into Photoshop and everything other than the structures were erased. In CA I used a standard sunset library backdrop to provide the sky effect. In the plan I placed a large psolid placed behind the model and used the cropped google street view as a texture. The psolid allowed me to manipulate the google street view to match the camera angle and I could use the texture offset controls to shift it and scale it. The psolid could also be moved forward or backwards to help obtain a sense of depth.
    28852
    CPDesigns
    CPDesigns
  • Similar Content
    • By pgjacob
      Hi All
      Can't figure out how to apply a backdrop to a walkthrough...
      thanks in advance
      melissa
    • By CBuserIndia
      I need help with the backdrop image or the external view image (view which is seen out of window).
      If you check sample video walkthrough (youtube link), when my camera moves through room, the outside image(view from window) looks un-realistic, it moves rapidly. It doesn't look proper.
      https://www.youtube.com/watch?v=H8-EjOgiS5g
      Image which I have used for outside is also attached in the thread. Also attached settings screenshot.
      Can you please help me find out what is wrong here ?
      Thanks
    • By Chief_Content
      Do you have a favorite backdrop image that you find works well for many of your projects?
      We are looking to accumulate a variety of examples that we can share with other users as a bonus catalog!
      If you would like to contribute any images for consideration as a backdrop, please send your samples to:
      content@chiefarchitect.com
      We have found that good backdrops typically have a horizon line at about 1/2 the height of the total image. They also need to be a minimum of 1920 pixels wide in order to have enough resolution on screen.
      *Any images submitted must be yours to share as owner and author. Please do not share other artists' work that you do not have rights and permission to distribute. Chief Architect may modify images for optimization and purposes and contact you for more information about any submitted images.
    • By B4UBLD
      Hi,
      Back again with spherical backdrop questions.  I have imported in a panorama backdrop (configured as spherical under the backdrop dialog) and have a question for anyone who may regularly do this.
      How does one obtain the desired orientation of the backdrop (e.g., if you want a specific view out of a given window)?What I have tried with some success for my particular case is to change the horizontal angle from 360 deg to 630 deg (vertical at 65 deg).
      I say "some success" because it looks great in regular camera view (and in final view with shadows), but becomes completely distorted in a raytrace.  It appears that it may be reverting to the original orientation and perhaps is not even displaying in a spherical format.
      If screen captures would help, please let me know...
      Thanks.
