Upward1 Posted October 30, 2020 Share Posted October 30, 2020 Tell me how you can move or cut off the foundation wall so that there is no intersection but the walls touch? Link to comment Share on other sites More sharing options...
Michael_Gia Posted October 30, 2020 Share Posted October 30, 2020 reverse one wall, and they won't connect Link to comment Share on other sites More sharing options...
Upward1 Posted October 30, 2020 Author Share Posted October 30, 2020 1 час назад Michael_Gia сказал: переверните одну стену, и они не соединятся решил проблему, но теперь стена отображается некорректно Link to comment Share on other sites More sharing options...
Michael_Gia Posted October 30, 2020 Share Posted October 30, 2020 I’m a little rusty with my Russian... From my knowledge of Greek I see the word “problemy” in there but that’s about it comrade. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted October 30, 2020 Share Posted October 30, 2020 I’m guessing if you’re still having problems you can add a short invisible wall at the junction going perpendicular. That usually works. Link to comment Share on other sites More sharing options...
RJBPILOT Posted October 30, 2020 Share Posted October 30, 2020 he said the wall flipped but is not displaying correctly now......but it did correct the connection issue.... 1 Link to comment Share on other sites More sharing options...
justmejerry Posted October 30, 2020 Share Posted October 30, 2020 You can copy the wall in the wall library under the build tab in top menu. Set the new copy to be a partition wall. It wall stop at other wall surface then. 1 Link to comment Share on other sites More sharing options...
Upward1 Posted October 30, 2020 Author Share Posted October 30, 2020 3 hours ago, Michael_Gia said: I’m a little rusty with my Russian... From my knowledge of Greek I see the word “problemy” in there but that’s about it comrade. sorry? I didn't notice how the translator turned on Link to comment Share on other sites More sharing options...
glennw Posted October 31, 2020 Share Posted October 31, 2020 You could try and make it a Partition Wall... or use the Edit Wall Layer Intersection tool. Link to comment Share on other sites More sharing options...
ACADuser Posted October 31, 2020 Share Posted October 31, 2020 Sometimes a room divider wall to nowhere will help with the intersection. Pull the one foundation wall back to break the connection. Drag a room divider wall from outside the house to intersect the foundation & then pull the other wall in to intersect. Tough to explain without a plan. Link to comment Share on other sites More sharing options...
