Upward1
cut foundation wall
Tell me how you can move or cut off the foundation wall so that there is no intersection but the walls touch?
1 час назад Michael_Gia сказал:
переверните одну стену, и они не соединятся
решил проблему, но теперь стена отображается некорректно
I’m a little rusty with my Russian...
From my knowledge of Greek I see the word “problemy” in there but that’s about it comrade.
I’m guessing if you’re still having problems you can add a short invisible wall at the junction going perpendicular.
That usually works.
he said the wall flipped but is not displaying correctly now......but it did correct the connection issue....
You can copy the wall in the wall library under the build tab in top menu. Set the new copy to be a partition wall. It wall stop at other wall surface then.
sorry? I didn't notice how the translator turned on
You could try and make it a Partition Wall...
or use the Edit Wall Layer Intersection tool.
Sometimes a room divider wall to nowhere will help with the intersection.
Pull the one foundation wall back to break the connection. Drag a room divider wall from outside the house to intersect the foundation & then pull the other wall in to intersect. Tough to explain without a plan.
    28864
    giabaogroup2012
    giabaogroup2012
