ACADuser Posted September 8, 2020 Share Posted September 8, 2020 Is there an automatic way to make a floor truss like a gable end truss? The floor truss sits on the wall and is built with vertical web members similar to a gable end truss. Link to comment Share on other sites More sharing options...
Kiwideziner Posted September 8, 2020 Share Posted September 8, 2020 Alan just a guess if you make the top and bottom chord lenghts 16 inches or whatever . Link to comment Share on other sites More sharing options...
joey_martin Posted September 9, 2020 Share Posted September 9, 2020 Unfortunately no. You can adjust a normal truss and make it a symbol I believe and add it to your library for later use. Link to comment Share on other sites More sharing options...
ACADuser Posted September 9, 2020 Author Share Posted September 9, 2020 Thanks, Joey I was afraid that was the answer. Graeme, I don't think that will work for me. Link to comment Share on other sites More sharing options...
robdyck Posted September 9, 2020 Share Posted September 9, 2020 32 minutes ago, ACADuser said: Thanks, Joey I was afraid that was the answer. Graeme, I don't think that will work for me. You can use a roof truss, just adjust its settings and polyline in a section view. Link to comment Share on other sites More sharing options...
robdyck Posted September 9, 2020 Share Posted September 9, 2020 17 hours ago, ACADuser said: Is there an automatic way to make a floor truss like a gable end truss? The floor truss sits on the wall and is built with vertical web members similar to a gable end truss. Interestingly enough, in my region, no builder would pay for those. Around here, the framers build parallel pony walls for all floor joist types. Its one of the simplest ways to ensure all studs are aligned, all point loads from window headers, beams and girders are transferred to the fdn, and the insulation values remain the same as all other exterior walls. Also, the small studs are a great way to use up crooked lumber. And it gives the framer's laborers a simple task to do while the lead concentrates on layout. 1 Link to comment Share on other sites More sharing options...
