Mintplanner Posted August 31, 2020 Share Posted August 31, 2020 Hello All, I've read some threads but didn't see my issue exactly, so here we go.... I need marketing floor plans for use in PowerPoint to obtain financing from a bank. I'm using the Export Picture feature, and trying to find an appropriate setting upon which Importing into PowerPoint, the jagged edges are gone and text is legible. I've found the "Do Not Reduce" image size setting in PowerPoint and checked the box. I've tried exporting floor plan views from Chief at various Pixels/Inch, but they all appear the same. My screen resolution is 1920 x 1080. Do I need to reduce my screen resolution? Thanks in advance, and I'm sorry I still us X7. Tim Link to comment Share on other sites More sharing options...
Mintplanner Posted August 31, 2020 Author Share Posted August 31, 2020 I just tested an import of .pdf into PowerPoint and it failed. Why? Because that's what my old school boss asked for. I've asked how he intends to share this information but he hasn't responded. If I could generate the presentation within Chief, that seems easier, but what if he wants fancy transitions? Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 31, 2020 Share Posted August 31, 2020 Does a screen capture saved to either jpg or png format not work? I have done many Powerpoint presentations over the years using just picture files. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 31, 2020 Share Posted August 31, 2020 Forgot to mention: I have a Saved Plan View (SPV) just for presentation views. That's what I use for my screen captures. Has only the info I need for marketing. You could do the same using Annosets (don't remember if X7 has those.) If not, just use a layerset modified to suit. Link to comment Share on other sites More sharing options...
Mintplanner Posted August 31, 2020 Author Share Posted August 31, 2020 I did attempt the screen capture, but it resulted in a little distortion. I used my layout as Eric suggested, and I think that'll get me through this assignment. I appreciate all the outside-the-box advice from you both! Link to comment Share on other sites More sharing options...
Mintplanner Posted August 31, 2020 Author Share Posted August 31, 2020 by the way, Holy Impressive Computer, Batman! Link to comment Share on other sites More sharing options...
Dermot Posted August 31, 2020 Share Posted August 31, 2020 You can only export plan views as images using your current screen resolution (or more accurately, your current window size). In theory, this image should not look distorted when brought into power point unless power point is adjusting the image size for some reason. You could try making the image larger in a photo editing program that might do a better job of enlarging the image with less distortion. Other things you might want to try would be to use a format that is vector based rather than raster based, such as DWG or EMF. If power point can't import either of these, you could maybe use another program to convert these into higher resolution images. Just as an FYI, you can export camera views to an image that is much higher than screen resolution if you like. I know that some people use top down floor overviews for making presentation floor plan views. Link to comment Share on other sites More sharing options...
Mintplanner Posted September 1, 2020 Author Share Posted September 1, 2020 Thanks for that explanation! I hadn't considered using the top down camera view either. Link to comment Share on other sites More sharing options...
MarkMc Posted September 1, 2020 Share Posted September 1, 2020 How about converting pdf to png? Lots of programs can do that, some free. 1 Link to comment Share on other sites More sharing options...
Mintplanner Posted September 1, 2020 Author Share Posted September 1, 2020 I suppose if the boss wants fancy transitions between pages, that's what I'll be required to do. Thanks for the tip! Link to comment Share on other sites More sharing options...
lbuttery Posted September 1, 2020 Share Posted September 1, 2020 I do historical presentations for my museum and extensive family history in the 1800's in the Niagara Falls region. I mainly use .jpg's in Chief's layout tool they are generally 40-60 pages in length I then save the layout to .PDF I find this easier to do rather than re-learn Powerpoint (I've had some classes) I don't have all the fancy transistions etc - but then again are they really needed ? If the .jpg's are saved directly from Chief to your HD I don't see why they couldn't be used in Powerpoint ? Another tool to consider is MS Onenote which allows for annotation of the .jpg's and live weblinks imports of emails and much more Lew Link to comment Share on other sites More sharing options...
