Bob_DeWitt_PE Posted August 26, 2020 Share Posted August 26, 2020 I'm looking for a better way to input actual field measurements for doing as-built floor plans, locating doors, walls, windows, etc. I'm considering purchasing a Leica Disto X3 or X4. Has anybody purchased a similar instrument for field input of distances? Troubles? Work Arounds? Sincerely, Bob DeWitt, PE Link to comment Share on other sites More sharing options...
MarkMc Posted August 26, 2020 Share Posted August 26, 2020 I had the X3 and worked just fine doing mostly interiors. I had been and still am input directly into CA via bluetooth without issue. (ran into a suggestion from Al Frey to take the numbers and enter manually from the device memory-will be trying that next time) I started to get more full houses where I needed to get exterior pitch and other dims. Sold the X3 and got the 7500i which Al suggested. It has a point-finder camera to see the dot long distance. The X4 also has a camera not sure the difference between it and the 7500i. I did have to get the firmware updated at the local Leica store since my phone wouldn't do it. The only downside is learning what each function does and how they work.Basic straight measures are a breeze though I bring a tape for short ones and just in case :) I keep a print out of the full manual which has more than the little quick start guide that travels with the device. I practice a bit the day before a measure, getting the hang of it. One of these days I may spring for their tripod and the simplest attachment, currently hacked onto a camera tripod I have. Look over the functions available, double check for the ones that require an adapter (more $$) and get the most you can justify out of the gate. BTW saw the 7500i on sale somewhere recently as an option. Shop around prices vary. 1 Link to comment Share on other sites More sharing options...
builtright3 Posted August 26, 2020 Share Posted August 26, 2020 I have the Disto E7500i and I love it! Great investment. Link to comment Share on other sites More sharing options...
parkwest Posted August 27, 2020 Share Posted August 27, 2020 I have an x4... works fine for what I need. 1 Link to comment Share on other sites More sharing options...
Francois Posted August 28, 2020 Share Posted August 28, 2020 Have you checked "appraiserslaser.com"? they have it on sale. I'll buy a (different) unit from them for they return policy and their support Link to comment Share on other sites More sharing options...
builtright3 Posted September 1, 2020 Share Posted September 1, 2020 On 8/26/2020 at 11:48 AM, Bob_DeWitt_PE said: I'm looking for a better way to input actual field measurements for doing as-built floor plans, locating doors, walls, windows, etc. I'm considering purchasing a Leica Disto X3 or X4. Has anybody purchased a similar instrument for field input of distances? Troubles? Work Arounds? Sincerely, Bob DeWitt, PE Hello Bob! Just following up; Did you make a purchase? Your decision and input could help others. Thank You! Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 1, 2020 Share Posted September 1, 2020 @builtright3 Joe, if you will add a "call" @Bob_DeWitt_PE he might respond. Otherwise, he may not come back to this thread for whatever reason. Thanks, Mike 1 Link to comment Share on other sites More sharing options...
mthd97 Posted December 14, 2024 Share Posted December 14, 2024 On 8/28/2020 at 6:40 AM, parkwest said: I have an x4... works fine for what I need. Hi, does it automatically send window and door sizes into CA ? BTW I do have the D8 for outdoor sunlight and long distance measurements even though that model will not always input into CA successfully. Looking at an X3 at this stage. Edit: The D8 will work with CAX10 space planning boxes and a windows surface tablet that has up to Bluetooth 4.0 with the older Disto D8 transfer software. Edit: I tested the Disto X3 with CAX10 (Lenovo ThinkPad X12 W11 BT 5.0) at a tools store and it works with door and window inputs but you must install the newer Disto transfer software for windows. For anyone who might view this post. Link to comment Share on other sites More sharing options...
