BBBuilders Posted August 25, 2020 Share Posted August 25, 2020 Has anyone had the problem of not being able to arch a triple set of mulled windows? I only have the problem in one particular plan. The window defaults don't give me the option for a arch window, it's grayed out. Link to comment Share on other sites More sharing options...
BBBuilders Posted August 25, 2020 Author Share Posted August 25, 2020 FYI - I am using X12 Link to comment Share on other sites More sharing options...
javatom Posted August 25, 2020 Share Posted August 25, 2020 You might have to create them. Draw cad lines where you want them. Block the lines to together and make a cad block. Click on the window and look at the bottom of the page for an icon that looks like the letter E. This is the "load muntins" button. It will turn the cad lines into muntins for that window. Link to comment Share on other sites More sharing options...
BBBuilders Posted August 25, 2020 Author Share Posted August 25, 2020 Plan size of 32MB is to large to attach. If I copy and paste a portion of the plan into a new plan I am able to arch the windows. I can arch windows that have not been mulled. Link to comment Share on other sites More sharing options...
rgardner Posted August 25, 2020 Share Posted August 25, 2020 3 minutes ago, BBBuilders said: Plan size of 32MB is to large to attach. If I copy and paste a portion of the plan into a new plan I am able to arch the windows. I can arch windows that have not been mulled. Do you happen to have them vertically mulled as well? If they are stacked windows try mulling just the upper set and doing it then milk afterwards. Link to comment Share on other sites More sharing options...
BBBuilders Posted August 25, 2020 Author Share Posted August 25, 2020 Just now, rgardner said: Do you happen to have them vertically mulled as well? If they are stacked windows try mulling just the upper set and doing it then milk afterwards. Thanks, but I have tried it both ways. It is a unit of 6 windows with the top 3 being arched. no mulled windows at any location in this particular plan can be arched. Link to comment Share on other sites More sharing options...
DzinEye Posted August 25, 2020 Share Posted August 25, 2020 Draw an exterior wall separate from your building and insert the windows onto it.... will they mull and arch? Link to comment Share on other sites More sharing options...
BBBuilders Posted August 25, 2020 Author Share Posted August 25, 2020 2 hours ago, DzinEye said: Draw an exterior wall separate from your building and insert the windows onto it.... will they mull and arch? no - windows in a new wall separate from the building will not arch Link to comment Share on other sites More sharing options...
DzinEye Posted August 25, 2020 Share Posted August 25, 2020 If you open an entirely new plan and try it do you get the same result? If so, that seems to me to say that there's something you should contact Chief about. If it works in a new plan there's something corrupted in your current plan and you might try copying everything into a new plan file. Link to comment Share on other sites More sharing options...
SNestor Posted August 26, 2020 Share Posted August 26, 2020 On 8/25/2020 at 12:51 PM, BBBuilders said: Has anyone had the problem of not being able to arch a triple set of mulled windows? I only have the problem in one particular plan. The window defaults don't give me the option for a arch window, it's grayed out. Yes...Chief will arch a window that has been mulled together. Watch this quick video. https://www.loom.com/share/a0f58f18e3004d5885e7b157088e580a Link to comment Share on other sites More sharing options...
DzinEye Posted August 27, 2020 Share Posted August 27, 2020 On 8/25/2020 at 9:51 AM, BBBuilders said: Has anyone had the problem of not being able to arch a triple set of mulled windows? I only have the problem in one particular plan. The window defaults don't give me the option for a arch window, it's grayed out. Did you figure it out? Link to comment Share on other sites More sharing options...
