SPSEngineering Posted August 22, 2020 Share Posted August 22, 2020 My firm has structural standards that are normally done in AutoCAD. I want to be able to achieve them in chief architect. This is our section annotation. I was able to create the top but I need help on the triangle on the tail. Also, is there a way to change the appearance or display the structural framing members as a polyline in plan view and have them as original in 3D? We currently use polylines for our joists, headers, girders, beams, rafters, etc. with a 1" to 3" Global Line Width and either phantom, continuous, or dashed/hidden line types in AutoCAD. I want to be able to produce our structural drawings like in chief architect instead of going back in forth because I like the auto framing features in chief. Let me know if additional files are needed for clarity. Or if this is the wrong forum for this topic. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 22, 2020 Share Posted August 22, 2020 You may need to wait for the release of X13 for the callout tails but for now you can draw them with cad or import from AutoCad and then keep them blocked in your library or template plan. See Plan Defaults for the 2D framing display : Line style and weight/colour can be controlled by layer. 1 Link to comment Share on other sites More sharing options...
SPSEngineering Posted August 22, 2020 Author Share Posted August 22, 2020 OMG! THANK YOU! Link to comment Share on other sites More sharing options...
rgardner Posted August 22, 2020 Share Posted August 22, 2020 7 minutes ago, Chopsaw said: You may need to wait for the release of X13 for the callout tails but for now you can draw them with cad or import from AutoCad and then keep them blocked in your library or template plan. See Plan Defaults for the 2D framing display : Line style and weight/colour can be controlled by layer. Just to add that setting is floor specific. So you will need to change it on all floors or set it that way in your template before adding any floors. Link to comment Share on other sites More sharing options...
HumbleChief Posted August 22, 2020 Share Posted August 22, 2020 10 minutes ago, Chopsaw said: You may need to wait for the release of X13 for the callout tails... or X14, or X15 or X16 or.......as Chief has been unwilling to add that simple feature (tails etc. to call outs) for many, many releases. A feature that many would use on every single plan. For now it has to be manually. 1 Link to comment Share on other sites More sharing options...
