kwhitt Posted August 7, 2020 Share Posted August 7, 2020 I've noticed that when I use the material adjustment tool that my textures will move. I often divide my backsplashes into parts so that I can represent a bullnose piece at the end. The first image is how it looks after much work with the material adjustment tool. The second image is how it will appear after moving around in 3D space and coming back to this camera view. The third image shows what happens when I again use the material adjustment tool to offset an arbitrary distance horizontally. The fourth image shows the result when I undo the last material adjustment. It goes back to the proper place. I have been texturing backsplashes this way since I started and never had any issue with X11. This happens all the time and makes getting the texture location just right an impossibility. Has anyone else noticed this? Thanks, Kevin PS - notice that the countertop texture has moved too even though I only adjusted the bullnose polyline solid. Link to comment Share on other sites More sharing options...
DzinEye Posted August 7, 2020 Share Posted August 7, 2020 You're not going to like this, but you need to have a different copy of each altered material each with it's own name. Each time you alter the SAME material def. it's going to change everywhere else you have that same material. Link to comment Share on other sites More sharing options...
robdyck Posted August 7, 2020 Share Posted August 7, 2020 Global Symbol Mapping. Link to comment Share on other sites More sharing options...
DzinEye Posted August 7, 2020 Share Posted August 7, 2020 24 minutes ago, robdyck said: Global Symbol Mapping. Just searched that and the first hit is Kevin's post... which you said the same thing. Link to comment Share on other sites More sharing options...
DzinEye Posted August 7, 2020 Share Posted August 7, 2020 Kevin, found this hit on the subject FWIW.. 1 Link to comment Share on other sites More sharing options...
DzinEye Posted August 7, 2020 Share Posted August 7, 2020 Well just read through that thread I linked above and my understanding of it is that all that happens when you use the 'un-check global symbol mapping' method and you do it correctly (which you'll need to see video from Eric and following comment from Mick... you find that all that's happened is that Chief has simply automatically made copies of the same material.. except they all will have the same name. So my take-away is it's much better to create your own named copies so you at least have some idea of what's what.. assuming your naming scheme is helpful in that regard. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 1 hour ago, DzinEye said: You're not going to like this, but you need to have a different copy of each altered material each with it's own name. Each time you alter the SAME material def. it's going to change everywhere else you have that same material. Mark - thanks for the reply. These are all copies of the original material and I am also aware of the use of global mapping. Something is definitely amiss here. How can one explain that the counter pattern changes too without any adjustment to the material. I swear I used this technique constantly in X11 and never had an issue. Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 35 minutes ago, DzinEye said: Just searched that and the first hit is Kevin's post... which you said the same thing. This is a different situation - sorta'. Kevin Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 4 minutes ago, DzinEye said: Well just read through that thread I linked above and my understanding of it is that all that happens when you use the 'un-check global symbol mapping' method and you do it correctly (which you'll need to see video from Eric and following comment from Mick... you find that all that's happened is that Chief has simply automatically made copies of the same material.. except they all will have the same name. So my take-away is it's much better to create your own named copies so you at least have some idea of what's what.. assuming your naming scheme is helpful in that regard. Mark - thanks for the post. I'll read that link in a few. Kevin Link to comment Share on other sites More sharing options...
DzinEye Posted August 7, 2020 Share Posted August 7, 2020 5 minutes ago, kwhitt said: This is a different situation - sorta'. Kevin So you're sure the material on your bullnose is a completely separately named material from your backsplash material? Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 1 minute ago, DzinEye said: So you're sure the material on your bullnose is a completely separately named material from your backsplash material? Absolutely positive. I sometimes have 11 or 12 copies of a tile pattern when doing a shower. The texture mapping is moving. I've been noticing this since I first installed X12. I'll see if I can prepare a sample file that illustrates the problem in a few hours and post. Link to comment Share on other sites More sharing options...
SNestor Posted August 7, 2020 Share Posted August 7, 2020 @kwhitt - you should post the plan or a sample plan. To quote Joe...”c’mon man”... 2 Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 28 minutes ago, SNestor said: @kwhitt - you should post the plan or a sample plan. To quote Joe...”c’mon man”... Hey Steve. That's what I said I was going to do and here it is. Go to full camera view "00". Don't move the camera. Simply double click on the piece of bullnose. When the dialog box opens, hit "cancel" or "okay". You might have to try it a few times with either "cancel" or "okay", but the texture will move. Really bad day to be quoting Joe! Thanks, Kevin Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 I'll have to work on the file AGAIN. Hate this file size limit. I spend more time purging files in order to upload. I have it at 13mb, but now telling me the limit is 10mb. Please stand by. Don't know that I've seen this message before... Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 @SNestor @DzinEye Finally! Here is the zipped file. Instructions above in an earlier post. Thanks for taking a look! Kevin CHF_REDACTED 08-07-20_PROPOSED.zip Link to comment Share on other sites More sharing options...
DzinEye Posted August 7, 2020 Share Posted August 7, 2020 2 minutes ago, kwhitt said: Here is the zipped file. Seems to be missing some of the texture files... no bullnose showing Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 3 minutes ago, DzinEye said: Seems to be missing some of the texture files... no bullnose showing You're right. Forgot about that. I will export again, but will probably be over file size limit. Thanks. Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 @DzinEye @SNestor Not sure I did this correctly. Please let me know if you're able to load the materials. I threw away all, but the backsplash textures. Kevin New folder.zip Link to comment Share on other sites More sharing options...
DzinEye Posted August 7, 2020 Share Posted August 7, 2020 Anyway... FWIW... I'm using the Adjust Material tool on the bullnose and nothings changing on the backsplash.... Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 11 minutes ago, DzinEye said: Anyway... FWIW... I'm using the Adjust Material tool on the bullnose and nothings changing on the backsplash.... Did you try as I instructed above by simply opening it by double-clicking and hitting "okay" or "cancel". If so, what were your results? Link to comment Share on other sites More sharing options...
DzinEye Posted August 7, 2020 Share Posted August 7, 2020 Okay... although I'm not seeing any changes on the backsplash, I am getting some weird behavior with the bullnose. If I use the Adjust Material tool and click on either the backsplash or the bullnose and then close the tool without changing anything the bullnose tile will change. Hmmm.... Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 @DzinEye Are you saying you are unable to try as you can't load the texture? If so, please advise me on the proper way to export the entire file with texture links in tact. This is first time I've done and used "back up entire plan". Link to comment Share on other sites More sharing options...
DzinEye Posted August 7, 2020 Share Posted August 7, 2020 1 minute ago, kwhitt said: Did you try as I instructed above by simply opening it by double-clicking and hitting "okay" or "cancel". If so, what were your results? The double clicking to open has had no effect (so far), but the Change Material tool certainly does... but you have to not change anything and say Okay.. if you Cancel nothing happens... and it's not consistent. Sometimes nothing happens. Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 2 minutes ago, DzinEye said: Okay... although I'm not seeing any changes on the backsplash, I am getting some weird behavior with the bullnose. If I use the Adjust Material tool and click on either the backsplash or the bullnose and then close the tool without changing anything the bullnose tile will change. Hmmm.... Mark. Yes, it's only the bullnose piece that keeps "jumping" around. I have seen this behavior for quite a while now. I do lots of custom showers and try to make the tiles center correctly as they'd be installed in reality. I waste more time trying to get everything aligned just so only to have it move. Thanks for taking a look. Kevin Link to comment Share on other sites More sharing options...
kwhitt Posted August 7, 2020 Author Share Posted August 7, 2020 1 minute ago, DzinEye said: The double clicking to open has had no effect (so far), but the Change Material tool certainly does... but you have to not change anything and say Okay.. if you Cancel nothing happens... and it's not consistent. Sometimes nothing happens. You're right. It's not something you can reproduce all the time - no consistency. This has been giving me a fit for a while now. Maybe I should send this to Chief. Link to comment Share on other sites More sharing options...
