1 quick option for this as-built would be to add a layer underneath the current main floor structure layers, about 36" thick and assign it the concrete material. Not structurally accurate, I know, but if you don't want to build a foundation...
Yup as Robert wrote either make the floor thick enough it extends under the terrain or build the foundation.  If you have already built the foundation then the foundation walls layer is turned off.
Look at the balcony too. Your floors are missing, and looks like the foundation either isn't built, or the foundation layer is turned off.
Your lower level porch slab is floating as well. No foundation.
    29482
    DuRoyAllen
    DuRoyAllen
