BeachHouse1 Posted July 30, 2020 Share Posted July 30, 2020 Sorry for not thoroughly searching for the answer to this. Any help would be appreciated. Is there a way to show wall framing details for multiple floors? Link to comment Share on other sites More sharing options...
joey_martin Posted July 30, 2020 Share Posted July 30, 2020 Wall details...like this? 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 30, 2020 Share Posted July 30, 2020 ..or Wall Details like this? Link to comment Share on other sites More sharing options...
BeachHouse1 Posted July 30, 2020 Author Share Posted July 30, 2020 On 7/30/2020 at 5:45 PM, Alaskan_Son said: ..or Wall Details like this? Expand Yes! Link to comment Share on other sites More sharing options...
BeachHouse1 Posted July 30, 2020 Author Share Posted July 30, 2020 On 7/30/2020 at 5:04 PM, joey_martin said: Wall details...like this? Expand This is not what I was referring to, but yes that would be nice. Thank you. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 30, 2020 Share Posted July 30, 2020 On 7/30/2020 at 6:58 PM, BeachHouse1 said: Yes! Expand You can either combine views in layout, or...what I usually do... Cut/Paste Hold Position all the framing from one wall detail to the other. The downside to this is that you have to check Retain Wall Framing for those walls or turn Auto Framing off. 1 Link to comment Share on other sites More sharing options...
BeachHouse1 Posted July 30, 2020 Author Share Posted July 30, 2020 Thanks Michael, 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 30, 2020 Share Posted July 30, 2020 On 7/30/2020 at 7:15 PM, BeachHouse1 said: Thanks Michael, Expand You betcha. Link to comment Share on other sites More sharing options...
joey_martin Posted July 30, 2020 Share Posted July 30, 2020 Mine are just back-clipped section cuts labeled and sent to layout. Link to comment Share on other sites More sharing options...
CadArchitect Posted August 1, 2020 Share Posted August 1, 2020 On 7/30/2020 at 5:04 PM, joey_martin said: Wall details...like this? Expand is there a tutorial on how to put an image like this together. i haven't come across one this detailed in the tutorial videos. thanks and great work Link to comment Share on other sites More sharing options...
Donco15 Posted August 1, 2020 Share Posted August 1, 2020 On 7/30/2020 at 5:04 PM, joey_martin said: Wall details...like this? Expand @Joey_martin - This is really an impressive graphic...Amazing layout... 1 Link to comment Share on other sites More sharing options...
joey_martin Posted August 1, 2020 Share Posted August 1, 2020 @CadArchitect this is my wall section page from a project. I use the back-clipped section camera, set it 12", and label accordingly. These are live section view sent directly to my layout page...no CAD from VIEW. Link to comment Share on other sites More sharing options...
joey_martin Posted August 1, 2020 Share Posted August 1, 2020 I always try to leave my wall section live, easier to clean up if there is a change. 1 Link to comment Share on other sites More sharing options...
rgardner Posted August 1, 2020 Share Posted August 1, 2020 On 8/1/2020 at 2:34 PM, joey_martin said: I always try to leave my wall section live, easier to clean up if there is a change. Expand Definitely agree with and learned this from Joey's awesome samples. It works really well with adding cadd masks on top of it and you can set the cameras on hidden layers so you don't even know the cross section is there but have an extremely accurate section. Just gotta figure out how @joey_martin adds those nice ends on the one sides of his plan view cross sections instead of the standard option or none. I am using that look but adding an arrow line. But if I adjust the end of the cross section line for fitting things in layout with the dimension lines I have to manually remove that arrow and place it on all floors. Link to comment Share on other sites More sharing options...
joey_martin Posted August 1, 2020 Share Posted August 1, 2020 They are just little CAD boxes set to the callout layer. Link to comment Share on other sites More sharing options...
rgardner Posted August 1, 2020 Share Posted August 1, 2020 On 8/1/2020 at 3:42 PM, joey_martin said: They are just little CAD boxes set to the callout layer. Expand ok, so no way to get them to auto-populate or stay connected to the cross section line? I need to adjust my workflow to add them later once I have sent everything to layout so that when I change where the tail of the cross section lines to be clear and not interrupt with dimension lines and be too confusing add the boxes at that time. Thanks for the tip. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 1, 2020 Share Posted August 1, 2020 On 8/1/2020 at 10:47 AM, CadArchitect said: is there a tutorial on how to put an image like this together. i haven't come across one this detailed in the tutorial videos. Expand I personally haven't seen Joey's plan/layout files, but when I create views like that, it's essentially done using Back Clipped Section views. Study and practice with the following tools and operations, and I think you'll figure it out: The Back Clip After setting for Cross Section/Elevation Cameras The Clip To Sides setting for Cross Section/Elevation Cameras Using Layer settings to control both what is displayed and what line styles/colors/weights are used for various items Using the Auto Detail tool and adjusting the automatically created filled polylines/boxes as may be necessary Adding your own Text, Dimension, and CAD objects to annotate and embellish as desired. Link to comment Share on other sites More sharing options...
CadArchitect Posted August 2, 2020 Share Posted August 2, 2020 @joey_martin those Backclipped Cross Sections are great! perfect work. can you share a pdf of that i could study, the png uploaded is low res. @Alaskan_Son thanks for the helpful info. I've been reading up on the sections you suggested all day now. very helpful information! do either of you make how to videos? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 2, 2020 Share Posted August 2, 2020 On 8/2/2020 at 1:41 AM, CadArchitect said: do either of you make how to videos? Expand I’ve made boatloads of ‘em. I actually make custom tutorial videos on a regular basis. I throw one out from time to time for free here on the forum and have quite a few available on my YouTube channel (link in my signature), but I also provide them as a paid service. Shoot me over an email to alaskansons@gmail.com if you want to discuss further and we can take it from there. Link to comment Share on other sites More sharing options...
CadArchitect Posted August 3, 2020 Share Posted August 3, 2020 @Alaskan_Son i watched all of your videos on youtube videos, very helpful. it would be nice if they had you make some of the official "how to" videos for CA, your sound quality is so much better. im trying to figure out how to make some of the call outs in CA like i would in AD rev example of what im trying to achieve: notice how there's anchor bolts in the footing shown and the beams have a out line through the view. on the foundation example there are detailed depictions of the terrain that makes up the ground on both side of the foundation also the aggregate that's laid under the garage slab. i cant seem to figure out how to do this level of detail in CA. are there search terms that i should be using to find info on this. any help is very much appreciated. thanks for helping, you guys are a wealth of knowledge! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2020 Share Posted August 3, 2020 On 8/3/2020 at 7:33 AM, CadArchitect said: @Alaskan_Son i watched all of your videos on youtube videos, very helpful. it would be nice if they had you make some of the official "how to" videos for CA, your sound quality is so much better. im trying to figure out how to make some of the call outs in CA like i would in AD rev example of what im trying to achieve: notice how there's anchor bolts in the footing shown and the beams have a out line through the view. on the foundation example there are detailed depictions of the terrain that makes up the ground on both side of the foundation also the aggregate that's laid under the garage slab. i cant seem to figure out how to do this level of detail in CA. are there search terms that i should be using to find info on this. any help is very much appreciated. thanks for helping, you guys are a wealth of knowledge! Expand I could definitely show you how to do all that in a custom video. Again, just shoot me over an email if you're interested in discussing further. In short though, most all of that is done using CAD tools and their Line Style/Fill settings and is sped up by familiarizing yourself with some of the various CAD productivity tools such as... Auto Detail Polyline Union Polyline Intersection Polyline Subtraction Trim Extend Stretch CAD Link to comment Share on other sites More sharing options...
