ChiefuserMathews Posted July 21, 2020 Share Posted July 21, 2020 how can I add custom notes to the library so that I can use in other layouts Link to comment Share on other sites More sharing options...
Chopsaw Posted July 21, 2020 Share Posted July 21, 2020 Do you mean text ? Marque select and block then add to library. 1 Link to comment Share on other sites More sharing options...
tommy1 Posted July 21, 2020 Share Posted July 21, 2020 40 minutes ago, Chopsaw said: Marque select and block then add to library. Exactly right. I have alot of notes that the city requires me to use in my plans...especially certain IRC notes. Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted July 21, 2020 Author Share Posted July 21, 2020 Thank you very much for the quick response. Instead of marque, I was selecting the text and could not get that option to add to the library. When I marque the text the option became available. Thanks again. Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted July 21, 2020 Author Share Posted July 21, 2020 Sorry I am withdrawing my reply. It didn't work. I did the marque, still I am not getting that option to add to the library. I am in the layout Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted July 21, 2020 Author Share Posted July 21, 2020 1 hour ago, Chopsaw said: Do you mean text ? Marque select and block then add to library. I tried that. Did't work. I am not getting that option to add to the library Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted July 21, 2020 Author Share Posted July 21, 2020 I found a way. I had to "make cad block" then add to library Link to comment Share on other sites More sharing options...
Chopsaw Posted July 21, 2020 Share Posted July 21, 2020 1 minute ago, ChiefuserMathews said: I found a way. I had to "make cad block" then add to library Yes that is it. Three steps. Link to comment Share on other sites More sharing options...
robdyck Posted July 21, 2020 Share Posted July 21, 2020 12 hours ago, ChiefuserMathews said: I found a way. I had to "make cad block" then add to library And, when you want to re-use it, you'll be placing a CAD block, not a text object, and it will be on the default cad layer. If / when you explode it, it will revert back to its original layer and you can also then edit the text if needed. Link to comment Share on other sites More sharing options...
