ChiefuserMathews
Add Custom Notes - Library
Do you mean text ?   Marque select and block then add to library.
Exactly right. I have alot of notes that the city requires me to use in my plans...especially certain IRC notes.
Thank you very much for the quick response. Instead of marque, I was selecting the text and could not get that option to add to the library. When I marque the text the option became available. Thanks again.
Sorry I am withdrawing my reply. It didn't work. I did the marque, still I am not getting that option to add to the library. I am in the layout
I tried that. Did't work. I am not getting that option to add to the library
1 minute ago, ChiefuserMathews said:
I found a way. I had to "make cad block" then add to library
Yes that is it.  Three steps.
And, when you want to re-use it, you'll be placing a CAD block, not a text object, and it will be on the default cad layer. If / when you explode it, it will revert back to its original layer and you can also then edit the text if needed.
    29338
    JonathanWilliams
    JonathanWilliams
  • Similar Content
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL   RABS INTEGRATED SINK - DL NEW!!! 03/26/2020
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL CAFE APPLIANCES, PAINTABLE(CORRECTED) - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4 RECESSED NC HALO 4 INCH LED WITH HOUSING - DL NEW!! 03-22-20
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL    BATH SURROUND TOOLS
      VIDEOS:
      YouTube Channel
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests 03-30-2020-6:49PM: Deleted Video Links and added link to YouTube Channel   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By ACADuser
      I have imported 50 or so items into the user library as furniture.
      Now I want to change all the items to another layer.
      How can I change all items to a new layer?
      The layer is now created.
    • By KTKArch
      (x11) When I open an object to fill (closed polyline etc) I have a standard list and the library option that takes me to Chief's library. It currently only shows that I have patterns of my own making in User Library. It also appears that I can no longer open 3rd party .pat files as I could in earlier versions. And finally, I cannot find a basic EARTH pattern in the defaults. So either I somehow purged some of the patterns or there isn't a default EARTH pattern. And how can I import my earlier .pat files? Not sure if this happened after installing x12 or if it is just this one file. Not using x11 but to finish out this project.
    • By WannabeDesign
      Working in Windows 10 on a surface pro laptop. All updates for Chief Architect Home Designer Architectural 2020 have been installed.
      The library keeps freezing me out of my plan when I type a 2nd search in the search bar of the library browser. I can see the cursor out of the plan window but can't do anything but save and close the program to start again. This is very annoying having to start and close the program continuously. Are there any fixes for this?
    • By ChiefAR-MARGARET
      I have spent hours trying to create note schedules for my layout. I cannot get rid of the 1st note schedule I created in my elevation. I have deleted everything and started over, opened new plans, tried to copy and paste, cad detail, etc. But it just isn't working! Every new note references other notes that are deleted, turn off, etc. And there are no videos to address this. They only show you how to do 1 note schedule. Thank you!
