Hot Keys not working on PC
dshall
I have a Mac,  hot keys work great.
My Dad has a PC ,  hot keys are not working.
He can have a plan and his hotkeys will not work.
I try importing hot keys,  can't do it.  I try customizing hot keys,  can't do it.  I take his plan and put it on my Mac and the hot keys works.
What could be the reason that the PC is not recognizing hot keys?  I am sure it is something easy to fix,  maybe a PC setting someplace that he inadvertently changed that turned them off.
thanks guys,
Yeah,  we did that,  there are 3 hotkeys in there,  I am not sure if they are even default hotkeys.  IAE,  I should be able to add a new hot key....  just one hot key and I cannot.  I have tried importing hotkey lists and I have tried adding just one hot key via the CUSTOMOIZE HOTKEY DBX,  it is a no go.
The attached pic is a pic of my list,  not the one from the PC.
It is so weird.  He called into tech and they suggested creating a hot key list ,  which is what you suggested,  so we did it and now what.?
1154983993_ScreenShot2020-05-26at8_45_55AM.thumb.png.232d94d0cb6050f208882ece237c89df.png
1 hour ago, dshall said:
Here is a pic of his hot keys
If he only has 3 hotkeys then I'd say Chief 's  .xml file in the Data Folder is corrupt ( or someone played with it :) )  as the Default file has 50-60 already setup...
there is a copy in C:\Program Files\Chief Architect\Chief Architect Premier X12 (64 bit)\Hotkeys
If he wants your HK file there should be no issue export yours and importing into his...... it's just a generic .xml file which PC's and MAC's should both understand with no issues.
Mick.
