SpeleoWorm Posted May 13, 2020 Share Posted May 13, 2020 Does anyone know if the Aerial View feature shown in this video was moved, removed or renamed? I can't find it under the View menu. Link to comment Share on other sites More sharing options...
Dermot Posted May 13, 2020 Share Posted May 13, 2020 Aerial view was removed. For a more complete list of what is different in X12, you may want to check out this migration guide: https://cloud.chiefarchitect.com/1/pdf/documentation/chief-architect-x12-migration-guide.pdf 1 Link to comment Share on other sites More sharing options...
SpeleoWorm Posted May 13, 2020 Author Share Posted May 13, 2020 Thanks Dermot! I missed that in the guide. Too bad, it looked quite useful (especially in a duplex/triplex when you are often jumping between the same room in each of the units). Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 13, 2020 Share Posted May 13, 2020 I actually liked the Aerial view tool, tooo bad its gone 1 Link to comment Share on other sites More sharing options...
Kiwideziner Posted May 13, 2020 Share Posted May 13, 2020 Saved plan views will do some of this. Link to comment Share on other sites More sharing options...
DzinEye Posted May 14, 2020 Share Posted May 14, 2020 On 5/13/2020 at 8:41 AM, SpeleoWorm said: Too bad, it looked quite useful (especially in a duplex/triplex when you are often jumping between the same room in each of the units). As Graeme said above... saved plan views is perfect for this example you give. You could have all three floors zoomed in to a particular room open at the same time...or just flip between them in the saved plan view pull-down. Link to comment Share on other sites More sharing options...
