Member Statistics
Similar Content
By Jackstacey
I'm having issues getting two joining external walls to have different materials and meet on the external corner ( pebble dash and brick) . I've checked my intersections and their mitered correctly and if i select ' through end/start' in structural for the wall it just shifts the issue to the adjoining wall. Please help?
By HannaForestAsh
When I place a window/door/etc. on a wall and type in the dimensions, sometimes it will move the edge of the wall instead of moving the window along the wall. (ie: if I have a 20' wall with a window on it, I want the length between the corner and the window to be 4'... instead of moving the window over on the wall, it will just extend the edge of the wall out past its original point so it's now 24'). Please help!! I'm not sure how to look up this issue so if there's a video on it already please direct me there!
By Ange822
I am using Chief Architect Premier X9
My defaults seemed to have changed so that when I select a window - it is now showing temporary dimensions of the window casing / center of window / trim. (see attached screen shots)
How do I change this to only show the window opening to wall stud?
thanks in advanced!
Angela
By Designer100
Hi,
I am trying to place columns and grid line with dimensions.
I have to create on column circles and columns lines , then the dimensions will not place correctly to center usining manunel dimensinos (its leaves 12in on each side of column center lines.
Chief Architect needs to be more friendly and have more commercial symbols and column lines to dimensions to them. They do have a commercial templet, but it does not have any of those.
Plus they need commercial window details etc. I am donating this for a non-profit to design a rendering and another area added on the back of this building.I am donating a rendering of exterior to help them fund raise $300.000.00 (by December) to buy the exist. building and remodel adding finishes to look better and another 2,000 s.f. to it.
Can anyone help me on working out the Grid center lines and will measuring correctly? turn on background and existing bldg. is under neath.
Thanks,
Newell
CA Premier x 12
Porter Road Floor Plan existing.PDF
Existing Building remodeling.Addition.plan
By sascea
Does anyone know how to change the decimal under the story pole marker lines? I've attached a picture, it's the numbers circled in orange. I would like to get rid of them completely as some of my story pole markers are close together and this takes up extra space.
Thank you in advance!!
