Ruby Room Area?
ACADuser
Looking at the ROOM data I'm not sure where the Room Area variable is.
Looking at Joe's macro, he used obj.room.internal_area.round(2)
It appears that the variable is already rounded. Not sure if this is new.
What I wanted is the area the Room polyline is based on.  369.83  --> Measurement
I see several area variables, but how to get the one I want?
How do you know what prefix to get the area you want?
Data Type: String
base_moldings ------------------- size = 1 ---------------------- Collection
[0] ------------------------- ------------------------------ NVPublisher
component_moldings ------ size = 0 ---------------------- Collection
description ------------- "base molding: PVC 4" Base" --- String
formatted_size ---------- "1x4" ------------------------- String
length ------------------ 600 in ------------------------ Measurement
room -------------------- ------------------------------ NVPublisher
SEE ABOVE ----------- ------------------------------
cantilever_underside_material --- ------------------------------ NVPublisher
id -------------------------- 133 --------------------------- Integer
name ------------------------ "Color - White" --------------- String
ceiling_elevation --------------- 108 in ------------------------ Measurement
ceiling_finish_layers ----------- size = 2 ---------------------- Collection
area -------------------- 373.153214 sq ft -------------- Measurement
material_data ----------- ------------------------------ NVPublisher
description --------- "Square Ceiling Tiles" -------- String
formatted_size ------ "24"x24"x1/2"" ---------------- String
quantity ------------ 93.5 -------------------------- Measurement
owner ------------------- ------------------------------ NVPublisher
thickness --------------- 0.5 in ------------------------ Measurement
[1] ------------------------- ------------------------------ NVPublisher
area -------------------- 369.825474 sq ft -------------- Measurement
description --------- "Color - White" --------------- String
formatted_size ------ "" ---------------------------- String
quantity ------------ 369.825474 sq ft -------------- Measurement
thickness --------------- 0 in -------------------------- Measurement
ceiling_finish_name ------------- "Color - White" --------------- String
ceiling_insulation -------------- ------------------------------ NVPublisher
area ------------------------ 369.825474 sq ft -------------- Measurement
cavity_r_value -------------- 0.0 --------------------------- Float
continuous_r_value ---------- 0.0 --------------------------- Float
depth ----------------------- 12 in ------------------------- Measurement
formatted_size -------------- "12x24x48" batts" ------------- String
length ---------------------- 48 in ------------------------- Measurement
num_batts ------------------- 46.25 ------------------------- Measurement
owner ----------------------- ------------------------------ NVPublisher
SEE ABOVE --------------- ------------------------------
width ----------------------- 24 in ------------------------- Measurement
ceiling_platform_layers --------- size = 1 ---------------------- Collection
area -------------------- 0 sq ft ----------------------- Measurement
description --------- "Steel Stud 24" OC" ----------- String
quantity ------------ 0 ----------------------------- Measurement
rebar_length ------------ 0 in -------------------------- Measurement
rebar_size -------------- 0 ----------------------------- Integer
thickness --------------- 2 in -------------------------- Measurement
ceiling_thermal_envelope_area --- 369.825474 sq ft -------------- Measurement
chair_rail_moldings ------------- size = 0 ---------------------- Collection
crown_moldings ------------------ size = 0 ---------------------- Collection
custom_pattern_scale ------------ 1.0 --------------------------- Float
dimensions ---------------------- "14'-10" x 23'-10"" ----------- String
drawing_group ------------------- default:_35_-_room_fill ------- Symbol
fill_line_weight ---------------- 1 ----------------------------- Integer
finished_ceiling_elevation ------ 107.5 in ---------------------- Measurement
finished_floor_elevation -------- 0.125 in ---------------------- Measurement
floor_ceiling_group ------------- 1 ----------------------------- Integer
floor_elevation ----------------- 0 in -------------------------- Measurement
floor_finish_layers ------------- size = 1 ---------------------- Collection
area -------------------- 371.216099 sq ft -------------- Measurement
description --------- "Floor-C4 Laminate" ----------- String
formatted_size ------ "1/8" thick" ------------------ String
quantity ------------ 371.216099 sq ft -------------- Measurement
thickness --------------- 0.125 in ---------------------- Measurement
floor_finish_name --------------- "Floor-C4 Laminate" ----------- String
floor_insulation ---------------- ------------------------------ NVPublisher
area ------------------------ 0 sq ft ----------------------- Measurement
num_batts ------------------- 0 ----------------------------- Measurement
floor_number -------------------- 1 ----------------------------- Integer
floor_platform_layers ----------- size = 2 ---------------------- Collection
description --------- "OSB-Hrz" --------------------- String
formatted_size ------ "48"x96"x3/4"" ---------------- String
description --------- "Concrete" -------------------- String
formatted_size ------ "4" thick" -------------------- String
quantity ------------ 0 cu ft ----------------------- Measurement
thickness --------------- 4 in -------------------------- Measurement
floor_thermal_envelope_area ----- 369.825474 sq ft -------------- Measurement
function ------------------------ "Living" ---------------------- String
internal_area ------------------- 370 sq ft --------------------- Measurement
layer --------------------------- rooms ------------------------- Symbol
layer_line_color ---------------- 2151678207 -------------------- Integer
layer_line_style ---------------- 111 --------------------------- Integer
layer_line_weight --------------- 18 ---------------------------- Integer
layer_set ----------------------- "Floor Plan" ------------------ String
layer_text_style ---------------- "Default Text Style" ---------- String
moldings ------------------------ size = 1 ---------------------- Collection
name ---------------------------- "Shared Medical" -------------- String
pattern_angle ------------------- 0.0 --------------------------- Float
pattern_horizontal_spacing ------ 8 in -------------------------- Measurement
pattern_vertical_spacing -------- 8 in -------------------------- Measurement
perimeter ----------------------- 1020.936748 in ---------------- Measurement
schedule_number ----------------- "R69" ------------------------- String
simple_schedule_number ---------- "69" -------------------------- String
standard_area ------------------- 389 sq ft --------------------- Measurement
stem_wall_height ---------------- 16 in ------------------------- Measurement
stem_wall_top_elevation --------- 0 in -------------------------- Measurement
type_name ----------------------- "Office" ---------------------- String
volume -------------------------- 3309.16752 cu ft -------------- Measurement
wall_coverings ------------------ size = 0 ---------------------- Collection
wall_material ------------------- ------------------------------ NVPublisher
id -------------------------- -32765 ------------------------ Integer
name ------------------------ "No Change" ------------------- String
Alan I think what you have highlighted is the ceiling paint area.  What you want is internal_area or standard_area.
It looks like you are using Joe's object properties macro ?  Either he has rounded those values off or your room is an exact dimension that just works out to a round number ( 14'-10" x 23'-10" )  but i did not check the math.
Thanks
This seems to work in a Rich Text object when placed in the room:
Not sure what I was domh wrom before.
# Macro Name: "room_internal_area"
# Displays the internal area of the room a Note is in.
# Copywrite by Joseph P. Carrick, August 2, 2019
# Macro --> myRoomArea
referenced ? obj= referenced : obj=owner
begin
rescue
"Failed to get Area"
end
  • 3 weeks later...
Ok, back to this project.
The obj.room.internal_area is a Chief rounded number.
I found obj.room.ceiling_insulation.area.round(3) was a close as I could come to the correct number.
If you select a ROOM and look at its properties you get this:
background_color_from_background..................... true
background_color_from_layer......................... false
base_moldings............................... [NVPublisher]
cantilever_underside_material................. NVPublisher
ceiling_elevation................................... 108.0
ceiling_finish_layers.......... [NVPublisher, NVPublisher]
ceiling_finish_name......................... Color - White
ceiling_insulation............................ NVPublisher
ceiling_platform_layers..................... [NVPublisher]
ceiling_thermal_envelope_area.......... 167.67399790629196
chair_rail_moldings.................................... []
conditioned.......................................... true
conditioned_is_set_to_use_default_value.............. true
crown_moldings......................................... []
custom_pattern_scale.................................. 1.0
dimensions................................ 12'-6" x 13'-5"
drawing_group..................... default:_35_-_room_fill
fill_color_from_background.......................... false
fill_color_from_layer............................... false
fill_line_weight........................................ 1
finished_ceiling_elevation.......................... 107.5
finished_floor_elevation............................ 0.125
floor_ceiling_group..................................... 1
floor_elevation....................................... 0.0
floor_finish_layers......................... [NVPublisher]
floor_finish_name....................... Floor-C4 Laminate
floor_insulation.............................. NVPublisher
floor_number............................................ 1
floor_platform_layers.......... [NVPublisher, NVPublisher]
floor_thermal_envelope_area............ 167.67399790629196
function........................................... Living
has_ceiling.......................................... true
has_floor........................................... false
has_floor_supplied_by_room_below..................... true
has_monolithic_slab................................. false
has_roof............................................. true
has_shelf_ceiling................................... false
include_in_living_area............................... true
include_in_living_area_is_set_to_use_default_value... true
include_in_schedule.................................. true
internal_area....................................... 168.0
layer............................................... rooms
layer_is_default..................................... true
layer_line_color............................... 2151678207
layer_line_style...................................... 111
layer_line_weight...................................... 18
layer_set...................................... Floor Plan
layer_text_style....................... Default Text Style
moldings.................................... [NVPublisher]
name.......................................... lab / blood
pattern_angle......................................... 0.0
pattern_color_from_background....................... false
pattern_color_from_layer............................ false
pattern_horizontal_spacing............................ 8.0
pattern_vertical_spacing.............................. 8.0
perimeter............................... 622.0000000000006
schedule_number....................................... R67
show_room_label...................................... true
simple_schedule_number................................. 67
standard_area....................................... 187.0
stem_wall_height..................................... 16.0
stem_wall_top_elevation............................... 0.0
transparent_pattern................................. false
type_name.......................................... Office
use_type_for_name................................... false
volume................................. 1500.3329604323415
wall_coverings......................................... []
wall_material................................. NVPublisher
If you make a Room polyline it follows the drywall perimeter and has an area of 167.67
Therefore the only other way to get close to the interior area is to use the dimensions & that too is rounded off.
    31392
    Jon2090
    Jon2090
  • Similar Content
    • By Renerabbitt
      Do you have 10+ years in the software and wonder if you've been missing some tips and tricks? Have you been able to break the 15 hour condoc set?
      Maybe you are a proficient user that wants to know everything that there is to know in Chief.
      Rendering, Automation, Resources, Symbols, Quick Tools, Style Pallets, PDF Tools, Templates, and more.
      We believe in lifting the community up. All of our tools and resources are available to you. With training that can be personal, team oriented, prerecorded, livestreamed, interactive. We offer training in over 15 softwares from Drafting and Detailing to Modeling, Advanced Texturing, Procedural Workflows, Node Based Design, Macro Creations, DAMs, Automation, VR Workflows, Streaming Overlays and Masks and much much more. Tell us your needs and we will connect you with the package or the right resource.
      Some example learning modules:
      Concentric Jump your dimension strings
      Enter-input your jumps and Enter-close your DBX's
      Snap jump your door widths, concentric jump your windows
      Alt behavior tips, contain-selection and deselection workflows with tool restrictions.
      Tons of cabinet tools and tips, including custom one-off parametrically modelled vanities and more.
      Custom Toolbar Icons and Custom Library Objects.
      Toolbar Switching Tricks and Library workflows
      Other Offer Services Posts:
    • By justin-c
      I'm trying to figure out if there is a way to display room occupancy load, using a text color tag.
      For example if a room was 100 ft.² and the fire occupancy load is 7 ft.² per person able to take the (room area divided by 7)
      the formula would also need to round up or down to the nearest whole number
      Here is the "Callout Specification" dialog window
      Here is the "callout tag" with the formula, but I would like it to be modified so instead it  show the red text or something similar
    • By ChiefuserMathews
      I would like to know if I could find total area of a room multiplied with .05 to find out glazing area required for that room in a text box using ruby macro
    • By HCremodel
      I am trying to create a custom texture detail schedule that references an object's texture and displays the assigned texture image. Problem is, I am fairly inexperienced with Ruby/macro in general although I have a very basic understanding. Has anyone created something similar to this, or have suggestions on how to get started with creating this type of custom macro? I am using Interiors 12X
    • By ccarpenter18
      In X12 I've noticed that when using Structural Member Reporting in a material list, the price column in the list does not appear to be sensitive to whether a "per unit" or "per length" calculation is being performed by the material list.  In both cases, the material list appears to use the same Price variable in the Component Panel of each object.  Does anyone know of some Ruby scripting that could be used to correct this?  Off hand, I'm thinking of a macro inserted into the Price variable on the Component Panel of each structural member that would use the Material List row context to report a price that depends on how the row wants to use the Price.
