buildinthevoid Posted April 1, 2020 Share Posted April 1, 2020 So I'm trying to add a pool to this roof, and I would like to adjust the flooring so that it slopes downwards from the step, rather than just staying flat. Any way I can go about it? Link to comment Share on other sites More sharing options...
Kiwideziner Posted April 1, 2020 Share Posted April 1, 2020 expirement with polyline solids drawn in elevation for the floor and end walls from the side then do the side walls and use boolen tools. Link to comment Share on other sites More sharing options...
buildinthevoid Posted April 1, 2020 Author Share Posted April 1, 2020 3 minutes ago, solver said: Where is the step? This part here Link to comment Share on other sites More sharing options...
VisualDandD Posted April 1, 2020 Share Posted April 1, 2020 A few years back I showed how to model a pool using terrain and curbs w/ custom profiles. Link to comment Share on other sites More sharing options...
rgardner Posted April 2, 2020 Share Posted April 2, 2020 Lora of techniques. Can use the ramp tool. Link to comment Share on other sites More sharing options...
DzinEye Posted April 3, 2020 Share Posted April 3, 2020 If proper construction is not an issue and you just need the look, cut a section through the pool, draw a closed polyline on the wall of the pool with the shape of the slope you want, turn it into a polyline solid, stretch it across the width of the pool, voila. Link to comment Share on other sites More sharing options...
