winterdd Posted April 1, 2020 Share Posted April 1, 2020 so the client changed the foundation on me after i completed the plans. not a big deal. went from a 4" mono slab to a raised 16" stemwall. now i am having problems running the new foundation. it creates the home but not the back covered porch or carport. all floor need to be 16" above grade. (2 blocks). any suggestions of what i'm doing wrong? Carl_Kristen_Wade3.plan Link to comment Share on other sites More sharing options...
winterdd Posted April 1, 2020 Author Share Posted April 1, 2020 yep, that worked. thanks, i was hoping it would rebuild it for me to make sure it was exact. but i got it. Link to comment Share on other sites More sharing options...
joey_martin Posted April 1, 2020 Share Posted April 1, 2020 For some odd reason, when using raised foundations, Chief will not build a foundation under porches. You have to put them in manually. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted April 1, 2020 Share Posted April 1, 2020 Steve Nestor has a good video on porches with foundation walls. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 1, 2020 Share Posted April 1, 2020 3 hours ago, joey_martin said: For some odd reason, when using raised foundations, Chief will not build a foundation under porches. You have to put them in manually. It will if you open those walls and tell Chief to Create Wall/Footing Below. Link to comment Share on other sites More sharing options...
rgardner Posted April 1, 2020 Share Posted April 1, 2020 5 hours ago, joey_martin said: For some odd reason, when using raised foundations, Chief will not build a foundation under porches. You have to put them in manually. Probably a regional thing. Most of the PNW has a 12-18” frost depth so lots of builders scrape your topsoil add your compacted fill then a 4” slab on top. No frost wall in a lot of those areas. Just put in a pc pier ftg for the posts. Link to comment Share on other sites More sharing options...
joey_martin Posted April 2, 2020 Share Posted April 2, 2020 6 hours ago, Alaskan_Son said: It will if you open those walls and tell Chief to Create Wall/Footing Below. But that will disable Auto Foundation, and I leave it on until wayyyy into my layout process. I generally leave the porch foundation alone and ignore that fact that they wont build until I am ready to deal with them. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 2, 2020 Share Posted April 2, 2020 13 minutes ago, joey_martin said: But that will disable Auto Foundation Not sure you're fully understanding. No need to turn Automatically Rebuild Foundation off. Simply open the walls defining the porch and set them to Create Wall/Footing Below... Link to comment Share on other sites More sharing options...
joey_martin Posted April 2, 2020 Share Posted April 2, 2020 Yea, I understood. I checked and that method does work now, in older versions it would kick you out of Auto Foundation. The foundation created matches the properties of the entire foundation though, which means for all the basements I do, I would still have to go back in the end of the layout process and fix the porch foundations. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 2, 2020 Share Posted April 2, 2020 4 minutes ago, joey_martin said: The foundation created matches the properties of the entire foundation though, which means for all the basements I do, I would still have to go back in the end of the layout process and fix the porch foundations. Ya. It's not gonna do everything. It gets you partway there though. Really depends what you're after I suppose. If for example you want to create a mono slab underneath you can still do that without turning auto foundations off. Link to comment Share on other sites More sharing options...
