buzzsaw204 Posted October 23, 2014 Share Posted October 23, 2014 hi how do i build a 2 or more landings set of stairs?? thanks, Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 23, 2014 Share Posted October 23, 2014 The key is patience and a methodical approach, making sure that each stair object fully connects to each landing edge. If the landings are wider than the stairs where you intend for them to connect to, be sure and add a manual break at the edge of each side of the stair object where it contacts its landing. For additional data please view the video tutorials offered by Chief Inc at their website under "Tutorials - Stairs" DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted October 23, 2014 Share Posted October 23, 2014 you may find it easier to add the walls 1st ( or use temporary walls) as the stairs and landings will "snap to" the corners and walls . stairs and landings usually are the same width but not always ,so David's tip is a good one .....use the break line tool to place a break next to the staircase on the landing's edge will allow it to auto join at the right height which it won't do without the break. M. Link to comment Share on other sites More sharing options...
HumbleChief Posted October 23, 2014 Share Posted October 23, 2014 If you build each stair from the bottom up in their proper location just click between the stairs, while still in the stair tool, and a landing will be created automagically between each stair. Link to comment Share on other sites More sharing options...
buzzsaw204 Posted October 24, 2014 Author Share Posted October 24, 2014 how about steps on the Landing, or a turning step?? Link to comment Share on other sites More sharing options...
Kbird1 Posted October 24, 2014 Share Posted October 24, 2014 They are called Winders , check the manual , but they need walls to snap to / limit them. forgot about HumbleChief tip ...another good one ,not well covered in the manual. EDIT Scott (dshall) has a bunch of free videos you can watch about 1/2 way down this page http://www.chieftutor.com/scotthall3/ M. Link to comment Share on other sites More sharing options...
buzzsaw204 Posted October 24, 2014 Author Share Posted October 24, 2014 i found this building Winders manually.... http://www.chieftutor.com/helpinghand/angledsteps.html pain in da butt..but will have to do Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted October 24, 2014 Solution Share Posted October 24, 2014 that video is from X2 , 4 versions ago , check your manual about winders , it is more automated now , perhaps Chief's video library is more upto date if you have SSA? you can also still do it that way too I guess though but your sig doesn't say what version you use..... see highlighted page 533-534 in the X6 Reference manual ( linked on X6 Help Menu) Winders must be in a room with valid room definition. You cannot create winders in an area composed of only 2 corner walls. If this configuration is needed, enclose the area in with Invisible walls so that a room area is defined To create winders 1. In an enclosed room area, place and connect the stair sections that you want to be winders. For best results: • The stairs should be two straight sections connected by a curved section between them; • The curved section should be adjacent to a 90° corner, as illustrated. 2. Select any subsection of the stairs and click the Open Object edit button to open the Staircase Specification dialog. 3. On the General panel, place a check in the box beside Winder and click OK. 4. The steps nearest the wall corner adjust their shapes and extend into the corner after the stair is changed to a winder. The Winders attribute directs the stair section to expand or contract to meet nearby walls, and can also be used to create a partial railing. See “Partial Railings” on page 535. Winders sometimes have treads that are too narrow at the inside curve. The Ignore Subsection Boundaries option can address this issue. See “Ignore Subsection Boundaries” on page 529. Link to comment Share on other sites More sharing options...
mschmokel Posted June 4, 2016 Share Posted June 4, 2016 I *just* inadvertently figured out a different way to solve the problem for my stairs that have two landings between the two legs of stairs and corner at the first landing: I created the top end with the specific number of treads, then a single tread 'stair' that I adjusted to the upper landing length, then the bottom end of the stairs with the specific number of treads. After tugging them into place, clicked for a landing. It only took me a year. Yay! Link to comment Share on other sites More sharing options...
