Dezigner99 Posted March 23, 2020 Share Posted March 23, 2020 I'm a kitchen and bath designer and when doing vanities - I often do not want to draw the entire room - just the ones where the vanity goes. But to use the NKBA Dimension tool i have to create an enclosed room - so I use room dividers to complete the box. How can I hide those on my layout plan drawings and just show the walls I want to show? Link to comment Share on other sites More sharing options...
rlackore Posted March 23, 2020 Share Posted March 23, 2020 Can you turn off the relevant layer? That should hide the room dividers. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted March 23, 2020 Share Posted March 23, 2020 Start with telling us what software you are using. And note how almost all of us here do it using the signature feature in our profiles. Link to comment Share on other sites More sharing options...
Dezigner99 Posted March 23, 2020 Author Share Posted March 23, 2020 Sorry - I'm a newbie. I just recently switched from 2020 to Chief Architect because I became frustrated with 2020's lack of ability to create a quality presentation and production quality drawing. I'm using Chief Architect Interiors X11 on a PC Laptop with Windows 10. Link to comment Share on other sites More sharing options...
Dezigner99 Posted March 23, 2020 Author Share Posted March 23, 2020 Yes! That worked. I didn't realize that invisible walls were their own layer and could be turned off. Thank you! Link to comment Share on other sites More sharing options...
Dermot Posted March 23, 2020 Share Posted March 23, 2020 When you select an object, the layer that it is on will appear in the status bar. If you select the Object Layer Properties tool that appears on the Edit toolbar or in the right-click context menu, you can open a dialog that will show you the layer properties for all of the layers associated with the selected object(s). From there, you can modify the display properties or even turn off the layer. There is a lot more information about layers and layer sets in the training videos. I highly recommend you search for videos related to them and review them. It should help you to become more efficient when working with Chief. These might be a good starting point: https://www.chiefarchitect.com/videos/watch/4/understanding-layers.html?playlist=100 https://www.chiefarchitect.com/videos/watch/5483/understanding-layer-sets.html?playlist=100 Link to comment Share on other sites More sharing options...
rlackore Posted March 23, 2020 Share Posted March 23, 2020 47 minutes ago, Dermot said: If you select the Object Layer Properties tool that appears on the Edit toolbar or in the right-click context menu, you can open a dialog that will show you the layer properties for all of the layers associated with the selected object(s). Thanks for the reminder about the Object Layer Properties tool - it's a gem that I don't use often enough. I've now assigned it a hotkey. Link to comment Share on other sites More sharing options...
rgardner Posted March 23, 2020 Share Posted March 23, 2020 1 hour ago, Dezigner99 said: I'm a kitchen and bath designer and when doing vanities - I often do not want to draw the entire room - just the ones where the vanity goes. But to use the NKBA Dimension tool i have to create an enclosed room - so I use room dividers to complete the box. How can I hide those on my layout plan drawings and just show the walls I want to show? Just FYI another way to accomplish what you want to do is actually create rooms and even floors to help with rendering and elevation views with shadows etc. I often times will do two different bathrooms on separate floors for the ease of switching back and forth and for layouts. When you send your plan file camera view to a layout you can then use the layout box to crop out the walls you don’t want to see. Link to comment Share on other sites More sharing options...
Dermot Posted March 23, 2020 Share Posted March 23, 2020 The Object Layer Properties tool is probably used less often now that we have the Active Layer Display Options (ALDO) dialog. The ALDO is basically a combination of the Layer Display Options dialog and the Object Layer Properties dialog that you can keep docked on your screen while you work. When you have an object selected, it will only show you the relevant layers and when nothing is selected, it will show you all layers. Unfortunately, Interiors X11 does not have the ALDO but the newer Interiors X12 does. If you are using Interiors X11 and your SSA is still active, you can get Interiors X12 now. Link to comment Share on other sites More sharing options...
